Overheats when accelerating
Hi people as the title says my car started overheating(4bars ap1) when the other day i was slight uphill with ~90m/h cruising i would say.
Slowed down a little and 3 bars again. After an hour i started it again and went to check it. Same story 4 bars after some hard acceleration i pushed some more and saw 5th bar for 2-3 seconds as i stopped it fell to 4th and after 10seconds 3rd again so i stopped pushing it and drove
Checked for leaks from first insident didnt found any nor coolant missing the other day from first overheat. Im thinking to do a comp test just so i can sleep at night cause i shit my pants when i saw 5th bar. Then if its ok ill try to flush the rad from these lentil-like inside that seem to have formed in the passages
Wonder if the little beads are hard deposits or gelatinous ? Hopefully they aren't sitting around the thermostat. For the relatively low cost of a nice aluminum rad I'd probably swap in a new Koyo rad.
To get it perfect you could remove the thermostat, block coolant plug, and then give it a good flush iwith high pressure water from a garden hose. It is a bit of work to remove the thermostat but worth checking if it continues to overheat and the rad flush doesn't solve the issue.
