Looking for list of components for K swap.
I'm sure I've missed it while searching, but could someone point me to a pretty definitive list of what components are necessary for the swap? I know the basic mounts, adapter, flywheel, but things like water outlet, water pump, oil pan, serpentine setup, AC compressor/lines is more of what I'm looking for.
Finished my K24A turbo swap recently on my AP2, here are some of the key components I have:
-Innovative engine / trans mount, red bushings -Balladesports trans adapter -Balladesports chromoly F to K flywheel -Low profile upper coolant housing (k-tuned but any replica of same design works) -Swivel neck thermostat (balladesports but also any replica) -USDM K24A2 water pump / alternator -K power industries idler pulley/tensioner delete (must get) -ASM intake manifold adapter with reused AP2 intake manifold -AC delete -Heater core delete |
Originally Posted by Caden Armentrout
(Post 25011779)
-Innovative engine / trans mount, red bushings -Balladesports trans adapter -Balladesports chromoly F to K flywheel -Low profile upper coolant housing (k-tuned but any replica of same design works) -Swivel neck thermostat (balladesports but also any replica) -USDM K24A2 water pump / alternator -K power industries idler pulley/tensioner delete (must get) -ASM intake manifold adapter with reused AP2 intake manifold -AC delete -Heater core delete Building a K24 in my backyard and eventually put it in a s2k. My question is: why do you have to delete the idler pulley, AC and heater core? How about engine harness and ECU? Should I swap it in 06+ s2k? Thanks, |
| All times are GMT -8. The time now is 01:56 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
