FS: MY03 White 680whp monster
Hi all,
Time to go different road came!So I Have to let my tressure go.Hope she will go in good hands :) Its 2003 car,fully build engine with about 2000 km after rebuild in April.There is two fuel maps,one for E80-683whp on 1,9 bar of boost and one for pump gas 497whp.Extremly fast car,a lot of work on her and amount of cash spent.Here is the list of what she has AEM Ems V2 Precision 6266 Gen 2 DW 1500cc new model for alcohol fuels Walbro 450 l/ph E85 version Fuelab Fpr-set to 4 bar base pressure Magnafuel external filter Custom fuel rail 10 bar fuel pressure sensor 10 an feed,8 an return lines Fully custom exhaust by JS-Design:Side winder manifold T 316 stainless,3' down pipe Tial 44 WG Darton sleeved block BC con rods CP 10:1 pistons ACL Race bearings set Oem head gasket Arp head bolts Hondata intake thermal gasket Brand new oil pump and cam gears chains Oil filter relocated Oil temp sensor Fully ported by "Progas Racing Team" head Supertech valvetrain master set kit+bronze guides Ti retainetrs Seats Springs Valves Tial 50 mm BOV Hondata 4 bar map Fast response IAT sensor 4xSPC adjustable ball joints Custom poly engine mounts BREMBO 4 pot BBK ...brand new 320mm rotors+brant new brake pads Nissan 300Zx TT R230 9' differential conversion Custom diff poly mounts Modified Oem prop shaft Modified Nissan drive shafts Rear subframe and suspension sand blasted and painted in last March Some poly bushes on rear suspension AEM Uego wide band controller HKS 60 mm boost meter Ebay brand oil temp gauge Racing aluminium radiator AC is working :) My topick :). https://www.s2ki.com/s2000/topic/101...s/page__st__25 Probably i miss some details :) Price:18000 Euros Car is Located in Varna, Bulgaria If any interes pls contact me via PM or email-dragostin1973@gmail.com I will try to present as much pics as i have Thank you! http://s19.postimg.org/fuvgn6xa7/20150718_143551.jpghttp://s19.postimg.org/miaddxim7/20151018_124428.jpg http://s19.postimg.org/rg11h5tdr/FB_...5236890654.jpg http://s19.postimg.org/432zynda7/rec...9800963068.jpg http://s19.postimg.org/or1nddyin/20150911_231548.jpg http://s19.postimg.org/6bx0ufypr/20151015_171135.jpg http://s19.postimg.org/xy4sopbwf/20151009_165221.jpg http://s19.postimg.org/jv2lzfnr3/20150721_111111.jpg http://s19.postimg.org/ttnklwx6n/20150813_193626.jpg http://s19.postimg.org/p91e6zdhb/20150624_164546.jpg http://s19.postimg.org/bgmzbcmpr/20150606_142917_2.jpg http://s19.postimg.org/vdswkb5kv/ima...eb8a38ad14.jpg http://s19.postimg.org/9351kc8an/ima...f1fb71b3f1.jpg http://s19.postimg.org/ama306akf/20151026_122954.jpg http://s19.postimg.org/6kszuii9r/20151026_122947.jpg http://s19.postimg.org/qyoq3ne9r/20151026_122248.jpg |
Very nice build. It's sad to see that you want to sell it. You will never have any monster like that. Think about it.
Best regards and good luck |
I know what you mean R-Poisen :thumbup:
http://s22.postimg.org/w0zre8r71/ima...8c65672e90.jpg Car took 3 rd place in 500+ street class 2 weeks ago :) 1,9 11,7 218 km/h. On Toyo r888 https://youtu.be/YXP0TXz10wI https://youtu.be/s84sECaiy0II https://youtu.be/pdTzLrBu-qc Got Brembos fited today :)))))) http://s29.postimg.org/6lv30xemb/ima...fe0e2ca4f8.jpg http://s14.postimg.org/la43iztul/rec...0630824984.jpg http://s16.postimg.org/lmimgsyz5/ima...f5b3722527.jpg |
Dyno day today!
1 bar of boost 497 whp 390 N/M pump gas http://s28.postimg.org/yco0co4yh/20151121_155525.jpg |
Up :)
Car worth more in parts |
Still ;)
New adjustable coilover suspension Meister R Zeta Pro 4 x brand new tyres Bridgestone Potenza Adrenalin |
