CA:Sleeved F20c,arias pistons,f20 crank,intake manifold,exhaust manifold
Means of contact: PM or email Location: Southern california, orange county -OEM intake manifold: good condition, clean with little/no scratches. Bare manifold only, will not come with accessories and attachments. Price: $75 plus shipping https://www.s2ki.com/s2000/uploads/g...099_143074.jpg https://www.s2ki.com/s2000/uploads/g...099_868964.jpg -OEM map sensor, came off of an 05 AP2 with ~60k miles. good working condition when taken off. Price:$30 plus shipping https://www.s2ki.com/s2000/uploads/g...099_458867.jpg krank vents, only used 1 for pcv, other unused, very lightly used for a few thousand miles: Price:$40+shipping https://www.s2ki.com/s2000/uploads/g...099_707374.jpg Gauge cluster that came out of my 05 s2000, approximately 75k miles when removed: Price: $200 plus shipping https://www.s2ki.com/s2000/uploads/g...099_811782.jpg Full-race aluminum intercooler piping. Should be the pipes that go from turbo to intercooler on their ramhorn setup. Never tested or mounted since I went with a fullblown turbo setup and had custom hot pipes made. Anodized/powdercoated black, pipes only, brand new: Price: $200+shipping https://www.s2ki.com/s2000/uploads/g...099_557278.jpg OEM coolant reservoir. Doesn't leak, replaced with an oil catch can/reservoir combo: Price: $10 +shipping https://www.s2ki.com/s2000/uploads/g...099_312990.jpg Air pump and EGR valve stuff. Not sure how complete, but should be all there, especially the big important stuff. Price: $75+shipping Motor mounts, aluminum mounts to engine not included https://www.s2ki.com/s2000/uploads/g...099_539774.jpg Row of metal tubes in upper left not included: https://www.s2ki.com/s2000/uploads/g...099_964637.jpg Stock s2000 shocks, springs, and top hats. complete, ready for bolt-up. No visible leaks, working fine when taken off, approximate miles, 40-50k Price: $170 plus shipping https://www.s2ki.com/s2000/uploads/g...099_387187.jpg OEM radiator with fans attached. Approximate mileage when taken off, 75k. Good working order when removed. Price: $100 plus shipping https://www.s2ki.com/s2000/uploads/g...7099_47881.jpg https://www.s2ki.com/s2000/uploads/g...099_226533.jpg Things not pictured: Complete engine harness, 2000-2005 Price:$150 plus shipping OEM radio out of an 05 AP2 Price:$40 plus shipping Coil packs, 4 from AP2 and 4 from Ap1: Price:$25 each or $90 per set plus shipping Parts located in southern california, Orange county area. Thanks for looking! Added turbo kit: Thanks for looking! |
What kind of sleeves?
Gonna be hard to sell that block for retail price with it at 90mm :(. What sleeves are those?
What is retail? Sleeves themselves sell for 600-800.installation is another 600-800, not including the bare Block and the decking to ensure a flat surface. Im not totally sure what sleeves they are, but theyre supposedly darton's?
Retail is like $1000-1100 for CLOSED DECK sleeves. These are open decks (def not Dartons) these probably retail for $900-1000
Look into it, trust me on this lol I know what I'm talking about. |
So that's for sleeves and install? From where? Darton, Benson, golden Eagle? I Had a friend get a sleeved block from darton and he paid around 1500, for sleeves and labor, not including block for a 4 cylinder honda. That's retail so I'm not sure which retail you're talking about. I've heard roughly the same, if not a little less expensive from golden Eagle.
CNC Engine Dynamics...they had them advertised a few weeks ago for $1000... They do AEBS, LA, and Dartons. These look like open deck LA sleeves which are even cheaper cause they arent the closed decks.
But what I don't understand is that this is 90mm that is as max bore limit on these blocks and really pushing the limits if you were to boost.. AND it's already been honed for the pistons which means its got a piston/wall clearance....depending on that clearance, this block may need custom pistons made. if you were to run it, when it gets wore out its done. Can't bore/hone and put bigger pistons cause its already it the limit. Not trying to bust your balls on the sale, just want people to know what they are getting themselves into. I would drop the price and let people know the deal with this situation. |
I'll probably drop the price within the week if I don't get more bites. This block was originally an na block which would probably be the ideal application.
prices lowered
