Mark this thread as Sold
Koyo Radiator , shroud and dual SPAL fans
I have build several of these for turbo charged build that have a tough time keeping the temps down.
This starts out a new Koyo Radiator with a custom aluminum shroud and dual SPAL fans.It uses a 12" Medium profile and a 13" Medium profile SPAL fan.Forget the other fans, SPAL is 100% the best fan you can buy.
Testing this in Atlanta in 100F temps with the AC cranking I never went over 200F, It's somewhat over kill.
$550 Shipped Via UPS.
Here's how it looks from above ( This is same kind on another car)
The Shroud is 20mm from the radiator, and the fan is 25mm thick at the out side and 60mm thick in the middle where the motor on the fan is.
I have the same fans mounted flush against a Mishi rad. If you need more clearance, you can dump the shroud. They make a nifty kit that mounts the fans flat on the radiator. This is a good deal. The fans alone are $300+...
The fan are awesome, I have never has in issue with SPAL over the last 10 years.
With the shroud it gives you about 40% more surface area that fan full air threw. This gives better cooling efficiency.I guarantee you will have no cooling problems with this and your AC will be even colder.
Joeh
09-07-2013 11:23 AM
brentd2319
Member S2000 Classifieds and For Sale
18
04-18-2009 04:51 PM
