Gateway S2000 Owners Members for St. Louis MO and area.
When does the VTEC kick in?
Old Feb 11, 2005 | 04:34 PM
rehile's Avatar
Default When does the VTEC kick in?
Hi!
Still have not really tested the new (used) car due to weather. I recall on the MY03 that the VTEC would throw you back in the seat around 5500 rpm at WOT. This MY02 starts at 6250 or 6500 rpm. What gives Any ideas?
Thanks,
Ron
Old Feb 11, 2005 | 04:58 PM
8BALL's Avatar
The My03's redline at 8K and the MY02's at 9K right? I'm not quite sure. If so, then it makes sense to me that you would kick into VTEC at around 6.2-6.5K. In MY01, I VTEV at close to 6.3K (when it is colder outside) so your observation would be correct. Hitting VTEC is also based on weather conditions. In the summer when it's hot, I VTEC at around 5.6-5.8K. You could also have a map sensor issue. Believe it or not, check your oil level or for any oil leaks
Here are some links with some feedback from the "Experts" which should answer your Questions:
Why Does My Vtec Engage At 6300?
vtec 6200??
What you're VTEC engage point
Power Problem VTEC?
Hesitation at vtec
Vtec Kick
Old Feb 11, 2005 | 05:08 PM
rehile's Avatar
8BALL,
Thanks!! I only saw one of these on a search earlier. That means -- My search criteria sux
Old Feb 11, 2005 | 05:16 PM
rehile's Avatar
Have now read these. Seems everything is normal. Maybe the previous CAI/exhaust accentuated the "kick" from VTEC?
Old Feb 11, 2005 | 06:13 PM
8BALL's Avatar
I would agree!
Old Feb 11, 2005 | 11:09 PM
folex187's Avatar
03 still has 9k redline. The vtec should be the same in 00-03. You might be used to hearing that violent change into vtec caused by the CAI. If you have the stock airbox the transition should be quieter.
rasulrasulinho
Jun 24, 2015 06:24 PM
darkfx
Mar 24, 2006 08:32 PM
Detroit
Jul 10, 2005 08:57 PM
StinkyTofu
Jun 4, 2005 09:37 PM
t00kosher
Sep 16, 2004 04:57 AM
