need a clutch alignment tool asap!
Anybody got a clutch aalignment tool I could borrow this weekend? Im doing n f22 swap in my ap1 and im in need of an alignment too to swap tha clutch! Please lmk asap!
clutch on the new motor only has 37k on it. the friction disc has a ton of meat on it and the pressure plate looks good. so im just gonna use the ap2 clutch and my ap1 flywheel(resurfaced) till i can get a SOS or ACT/OEM setup. the 3k i spent on the motor set me back a little.lol
Nah that makes perfect sense man. I figured if you had a lot
Of miles on the clutch it's worth it but that ones a baby still. Seriously a clutch alignment tool can only run you 5 bucks tops new clutches usually come with them
yeah it took a little inginuity but i made one that should work quite well... took a 3/8 extension and used a short 13mm 3/8 impact socket(its thicker than the normanl 13mm socket) it fits snug in the crank. than i took a short 16mm 1/2 impact socket for the friction disc and slid the socker over the entire extension than placed the 13mm on the end like normal. tested it on the f22 and sits almost perfect.
