AP1 Valve Reatainers and Keepers Help!
Aloha,
i purchased my dream car last October from Pacific Honda. An 20000 AP1 s2000, I'm not going to lie it probably seen better days but i still love it and its still a joy to drive! So as of recently I want to keep her going, so I wanted to do some preventive maintenance. So I've done some things already, took a park the differential and serviced it. And found out from s2k Chad that my particular car has a 4.77 Final Gear Drive, Previous owner. Replace Prop shaft (broken front seal, CV grease everywhere), replaced clutch master cylinder and slave, spark plugs (cylinder #4 all the threads was covered in oil, replace the rubber grommets), change tires to Yokohama S Drives, and stop tech pads. So now i really want to change the famous retainers to the AP2 retainers. I bought new retainers and keepers in December knowing I wanted to do them eventually. I'm already hearing a Valve Tapping noise. So by any chance the community could help me with replacing my valve retainers and keepers? I seen that a tech day is coming up. I don't have a valve spring compressor tool, so I would really appreciate the help! Or could someone point me in the direction to someone who could do valve adjustment and replace the retainers and keepers?
Mahalo,
Mahalo,
I don't have a valve spring compressor but I can help you do a valve adjustment. It's not hard, it's just time consuming.
You should probably inspect the retainers and have them replaced before the adjustment.
rjtrout2000
04-11-2018 01:04 PM
obsess2k'ed
40
07-15-2015 08:28 AM
skinsfn36
09-18-2012 09:42 AM
molotovsoldier
03-14-2010 09:13 AM
