Hawaii S2000 Owners S2000 Owners in Paradise Hawaii Owners
i fuked up my car... :'(
Old 03-27-2006, 12:31 PM
NSRsinfuLangeL's Avatar
Default i fuked up my car... :'(
i dunno what i did. i changed the tranny fluid to the honda one but i still have trouble getting it on gear and especially reverse and i notice my clutch ha s a lotta play now. so i topped off the clutch fluid but still a lotta play :/
help!!
Old 03-27-2006, 01:13 PM
L8-APX's Avatar
air in the system?
Old 03-27-2006, 02:20 PM
hahnn002's Avatar
If it's air in the system I can flush the clutch fluids to get any air out and try another trans fluid change if you want. I didn't have problems this bad but my shifting got a lot better after I went with some GM Synchromesh in the transmission. Also, what kind of brake fluid did you use to top off the clutch? If flushing the fluids doesn't fix anything then you'll probably have to get the trany inspected.
Old 03-27-2006, 02:57 PM
jzz30's Avatar
yea i thought your clutch felt really funny. all the travel it had was to engauge the clutch and the rest felt like peddal play. maybe Mr. slave is tired and in need of attention
Old 03-27-2006, 02:59 PM
kent-k's Avatar
i have a stock 05 slave somewhere. lmk if you need it. i changed mine to an 03 a long time ago
Old 03-27-2006, 03:07 PM
yeah i'm gonna bleed the clutch soon. my shifter seems like its getting better.
Old 03-27-2006, 03:08 PM
jzz30's Avatar
try change the oil again to get more residual oil out
Old 03-27-2006, 03:10 PM
the clutch fluid? i using DOT3 does it have to be HONDA dot3?
Old 03-27-2006, 03:11 PM
kent-k's Avatar
i don't think so.
Old 03-27-2006, 03:14 PM
s2kboy808's Avatar
here is a link if you are gonna do it yourself
http://www.s2katlanta.com/~s2katl/fo...read.php?t=909
as for the trans fluid drive it around get all the gears spinin but bleed out the clutch first. the link will show you how.as long as the gears arnt grinding you should be ok
maybe your clutch is going? does your clutch pedal get stuck? or just grabs higher
link for 00-03 clutch master cylinder ebay http://cgi.ebay.com/ebaymotors/CLUTCH-MAST...046384478QQrdZ1
Quick Reply: i fuked up my car... :'(
