Chopping Down Rick's Aeroscreen
Old Feb 25, 2003 | 12:33 PM
S2KXTC's Avatar
Default Chopping Down Rick's Aeroscreen
I've got Rick's 7/8 Aeroscreen and well...my bumpers popped off again. It seems to catch a little too much wind, so I can't seem to get it to stop rattling without using the bumpers and they've popped off three times now. I thought it might be better to have the screen shorter, maybe a few inches higher than OEM.... Anyone have an idea what tools I could use to have this done? The rattle drove me nuts for way too long, so now the screen is down until I can figure out a solution.
Old Feb 25, 2003 | 01:12 PM
ricklobo's Avatar
a laser cutter, if you have access, is your best bet... otherwise, back to stock I guess....
Old Feb 25, 2003 | 01:19 PM
nsx555's Avatar
I made a windscreen a bit higher than the roll bars. In order to get into the secret compartment, I had to turn the whole mechanism around, and fold the windscreen into the cabin while lifting up the lid of the secret compartment. To stop the screen from blowing into the car at speed, I slit 2 pieces (about 6" each) of 5/16" fuel line down the center and pushed it around the sides, or rather, pushed the windscreen into the groove of the fuel line. Now it fits rather tight and doesn't blow in or rattle.
You might be able to do something crude like this. I know a lot of people wouldn't, but the black rubber on the sides touching the roll bars really doesn't look too bad. I will look for some pics to post.
Old Feb 25, 2003 | 01:45 PM
Muz's Avatar
Muz
Chopping down a Lexan aeroscreen is not something you would normally try yourself. I'd imagine re-polishing the edges would also be quite difficult. It's definitely a machine process. If you can't find a glue that does the job there are also 7/8 one piece aeroscreens you might want to consider rather than returning to the less effective stock version. They never move and are quite inexpensive.
Old Feb 25, 2003 | 04:41 PM
S2KXTC's Avatar
There are no tools that can be used to cut through the plastic? I would think there has to be something.... I don't want to go back to stock....
Old Feb 25, 2003 | 05:18 PM
S2kRob's Avatar
You can get a special plexiglass bit for your Dremel that won't melt it as you cut it.
However, try the fuel line mod. I just got my 7/8 screen and that's what I'll be doing rather than crazy glueing stuff onto my roll bar covers.
Old Feb 25, 2003 | 07:26 PM
Rick Hesel's Avatar
Which bumpers do you have? We're now supplying bumper strips which will not come off.
Email me your address at hesel@artsci.com and I'll send you a set.
Rick
Old Feb 25, 2003 | 09:08 PM
xviper's Avatar
I cut little notches in those bumpers and used some industrial strength crazy glue. They have never budged.
Old Feb 26, 2003 | 05:41 AM
S2KXTC's Avatar
[QUOTE]Originally posted by Rick Hesel
[B]Which
Old Feb 26, 2003 | 06:06 AM
xviper's Avatar
A thought: Did you rub off the plastic protectant really well with rubbing alcohol, then let it dry before putting them on. If there is even a little protectant on there, nothing will stick to it for long.
