Clicking from left rear of car when just starting out from a stop
Old Jul 5, 2002 | 08:06 AM
rjm161's Avatar
Default Clicking from left rear of car when just starting out from a stop
Hey All
The search function being down, I thought I'd throw this one out there.
When I just start to inch away from a stop, I get a clicking noise from the left rear of the car. It sounds like it is maybe coming from the wheel or suspension. This morning I noticed that it also happens when downshifting just before I stop.
The sound is tough to describe...almost sound like when you have a rock in your tire. I checked for spring spacers...none.
Just wondering if anyone else has/had a similar issue.
Thanks!
Old Jul 5, 2002 | 08:42 AM
wanabe's Avatar
since it is only at low speeds, i wonder if you have something inside the tire? not likely, but the symptoms point there...
trip to the dealer is in your future, i.m.o.
Old Jul 5, 2002 | 08:43 AM
Elistan's Avatar
I had that noise, didn't do anything about it, and after a while it went away.
Old Jul 5, 2002 | 10:01 AM
2Scars's Avatar
Mine just started doing that. Approx 32k on car. Tires are about shot, no obvious cause on visual inspection.
Old Jul 5, 2002 | 10:34 AM
darth_2k's Avatar
I get it too. Can someone out there help?
Old Jul 5, 2002 | 10:49 AM
j2k's Avatar
j2k
Sounds to me like you might have the beginning of a wheel hub/bearing problem. You can try to tighten the spindle nut... if that makes it go away then that's probably what it is. If you were to pull out your wheel hub... it might look like this (yours wont have such long wheel studs ):
note the wear/pitting on the inboard half of the snout thingy... this is not normal. This will cause play in the assembly and will cause a clicking like you described.
-jason keeney
Old Jul 5, 2002 | 11:07 AM
CoralDoc's Avatar
Possible reasons for clicking:
1) Stone or nail in tire
2) CV joint
3) Bearing (as j2k illustrates)
You can eliminate the tire issue by careful inspection and swapping wheels with someone
The CV joint and bearing issue are only noticeable upon teardown and inspection. Good luck.
Old Jul 5, 2002 | 11:46 AM
rjm161's Avatar
Thanks, all
I am pretty sure it is not anything to do with the tire itself....I checked pretty thoroughly.
I am due for an oil change so I will have them look at it.
Old Jul 5, 2002 | 12:45 PM
dlq04's Avatar
REAR AXLE NOISE
A small number of owners report Rear Axle Nuts problems. Rear axle nuts are not loose, they just need to be retorqued to keep the hub from shifting on the axle splines which make the tick tick noise. The axle nut is "staked" and will not come loose from the axle. This is distinguishable by a clicking sound during quick starts in forward or reverse; however, don
Old Jul 5, 2002 | 12:47 PM
H82W8's Avatar
I've got this same clicking. I first noticed it going through a drive through window where the sound echoed off the brick wall. I've taken it to the dealer and they told me " It's Normal and their other S2000's do it too". I don't think this is normal and am interested to see what others find out.
BTW my car only has 10k on it.
