What are the MY2000 and MY2002 spring and damper rates?
Old Jul 10, 2002 | 11:36 AM
jerrypeterson's Avatar
Default What are the MY2000 and MY2002 spring and damper rates?
I assume the MY2002's springs are stiffer, shocks softer. Also, are the mounts identical?
Old Jul 10, 2002 | 11:54 AM
pll's Avatar
pll
2000-2001: (according to that Honda tech doc)
Front: 38.3 N/mm (219 lbs/in)
Rear: 51 N/mm (291 lbs/in)
The 2002 does seem stiffer.
Side question: When you go over uneven pavement (gaps in the road, man hole covers, etc), does the suspension make a loud thud/thwap noise? Last year, one of my shocks died and made a much louder noise (metal on metal). This noise is not as loud, but still sounds like the suspension is hitting hard.
Old Jul 10, 2002 | 05:26 PM
The noise you are describing reminds of when I was riding on the bump stops in my CRX. The shocks were all blown from lowering the car, but you didn't lower your car. Hmm.
If those numbers are correct for the MY2000-01... uhh wow. Does any one have the rates for the 2002's?
Old Jul 12, 2002 | 01:32 PM
Gregg Lee's Avatar
[QUOTE]Originally posted by jerrypeterson
[B]I assume the MY2002's springs are stiffer, shocks softer.
Old Jul 12, 2002 | 01:50 PM
In light of the above, a subquestion:
Are the stock front/rear springs interchangable?
Old Jul 13, 2002 | 09:55 AM
Gregg Lee's Avatar
They have the same coil diameter (about 4 1/4 inches) and coil count (6 1/4). So they are interchangeable in the sense that they fit the seats. The different rates would affect ride height since stiffer compresses less, etc.
If Honda varies the spring length so that different rates give the same ride height, and since front and rear corner weights are about the same, then you could interchange.
My stock my2000 springs have color dots on then by the way, if any one has the code. dots on three adjacent coils. front is blue blue red, rear is blue red red.
Old Jul 15, 2002 | 08:32 AM
What is pricing on the springs from Honda? I may try experimenting with different stock springs for the car.
Old Jul 15, 2002 | 08:47 AM
Jason Saini's Avatar
Just an FYI, the rear '02 swaybar has the same diameter but a thinner wall, and the front bar has both a smaller diameter and wall. Also, I know the shocks have different part numbers, but I'm not sure if they are stiffer or softer.
Old Jul 15, 2002 | 02:27 PM
Nimbus's Avatar
[QUOTE]Originally posted by Jason Saini
[B]Just an FYI, the rear '02 swaybar has the same diameter but a thinner wall, and the front bar has both a smaller diameter and wall.
Old Jul 15, 2002 | 04:02 PM
