how do you wash your engine?
i was just wondering the best way to clean some of the dust and road grime from my engine compartment. is there a preferred cleaner solvent? is a power sprayer ok? thanx for the advice.
I have used Simple Green or a product like that for years. Stay away from pressure sprayers. They get water into places that will cause problems. Also stay away from Steam cleaning for the same reason plus the steam heat will harden plastic quickly. I flush with water from a hose and then blow dry the engine compartment.
I'm sure that a leaf blower would work, but, I have access to compressed air. I haven't had electrical problems because I am not using pressure water to wash off the engine cleaner and the compressed air cleans all the water off.
http://safety.army.mil/pages/lessonslearne...mplegreens.html
http://www.safetycenter.navy.mil/media/ash...mourreaders.htm
I use a few micro-fiber towels dedicated to getting grungy with a damp wipe. If anything is too stubborn, a little WD-40 on a seperate cloth will usually clean it up.
If you do use a power washer, be very careful to avoid spraying directly at seals, gaskets, and any electrical components.
I wanted to mention, as the above poster:
STAY AWAY FROM HIGH-PRESSURE.
I went mud-bogging in my truck once... decided to take the garden hose w/sprayer and clean up a bit.
It took me 1 >week< to get it started again. Everyday was 100f+ out too, and still took at that long to dry out.
I'll never-ever-ever do that again.
-- Aaron
-- Aaron
