Cig. lighter/power outlet loose - help!
Old Nov 1, 2001 | 09:02 PM
rstark's Avatar
Default Cig. lighter/power outlet loose - help!
My power outlet for some reason is loose, can someone with a helm's manual post instructions for removing panels to gain access to this? I've tried once in the past, and those panels are tough to remove without instructions. Thanks.
Old Nov 2, 2001 | 03:15 AM
turbo_pwr's Avatar
Are you sure you want to do it? Take it to the dealer. Looking at the manual you will need to remove the Center Console, Rear Tray, Roll bar lower trim (both sides) in order to get to the rear console. That's a lot of work for a power adaptor.
Old Nov 2, 2001 | 03:43 AM
a_MAY_zing_1's Avatar
I took mine to the dealer a couple of months ago and they fixed it. But it's loose again. I only use it for my cell phone car charger.
Old Nov 2, 2001 | 04:59 AM
airgate's Avatar
Hmmmmm. . .I had this same problem with my '00 and it was quite annoying. . .
I always feared the adapter would come out. . .I tried to use "extra" care when removing the power adapter. I also use mine for the cell phone. When I mentioned it to the Honda dealer, they said it was normal. . .of course!
Old Nov 2, 2001 | 09:57 AM
jschmidt's Avatar
I fixed mine recently and put some thread locker on the collar. So far it is holding.
To get to it, remove the panel behind the driver's seat (which is held on by the coat hook and a few clips) then remove the screws from the bottom of the center area (with the compartments. You can then reach in and tighten the PP screw collar. It tightens by hand. 10 minute job.
Old Nov 2, 2001 | 02:10 PM
moyopoyo's Avatar
the same exact thing happend to me, but the second time it came out, it had stopped working. i just took it to the dealer, and they did it without arguing (that was a first).
Old Nov 3, 2001 | 06:06 AM
00SType's Avatar
You've got mail.
Old May 30, 2004 | 11:25 AM
BioBanker's Avatar
to jschmidt for saving me a few hours today. Couldnt figure out how to do it till I dug up his post.
I did what he posted and ten minutes later I was good to go again.
Waydago to another helpful S2Ki member jschmidt
AZS2KDancer
Aug 23, 2013 05:04 PM
OhioRacer
May 14, 2009 08:44 AM
Lawnmower
Jan 20, 2007 01:25 AM
Vixen
Jan 3, 2005 09:00 AM
Rickjames
Nov 30, 2004 02:58 AM
