Headlamp condensation? ? ?
Old Dec 27, 2006 | 01:53 AM
Lloyd Six's Avatar
Unhappy Headlamp condensation? ? ?
Some of you will find this interesting, I know, I know yet another wet headlamp post but get this... A few weeks back I did the full job on my condensated (new word!) headlamp where as I removed the bumper, took out the lamp, dried it all out 100%, baked it, re-sealed it, took it to bed, gave it lots of warm loving and put it back in with the equivalent of 04> rear seals (filled the vents up with silicone).
So there it is looking all crystal clear and sparkly...
Two days later and it
Old Dec 27, 2006 | 03:25 AM
mikey k's Avatar
Sealing it up complete will cause that problem as you seall moisture in. As the tmeperatures change it condenses out.
I discovered this when I had the same problem with my 00 car a couple of years ago. All I did was dry it out in the airing cupboard and reseal the joint between the two halves. I blocked all the vents up like you and had the problem again. Putting it back as Honda intended it went away.
I guess they are called vents for a reason
Old Dec 27, 2006 | 07:36 AM
Nottm_S2's Avatar
I had this only the other day.. did the dry out with a hairdryer thing and left well alone..
it came back but much less than before and i left it (vents unmolested)..
it's mostly dry now, i've just washed the car so will see what it's like tomorrow
Old Jan 1, 2007 | 07:24 AM
Simoted's Avatar
I took the rubber seal off a couple of days ago and my headlamp is now looking as good as new!, Cheers matey
Old Jan 1, 2007 | 11:37 PM
Lloyd Six's Avatar
Glad to be of assistance... mine is perfect now, took about a week to completely clear.
Old Mar 8, 2007 | 11:06 AM
Nath's Avatar
Lloyd, the seal for the main bulb how do i get to it, from under the bonnet or through the arch liner?
if anyone has pics that would be ace!
Old Mar 8, 2007 | 12:02 PM
AquilaEagle's Avatar
Administrator
Through the arch liner - needs to come RIGHT back though - tricky to get at
Old Mar 8, 2007 | 12:23 PM
mikey k's Avatar
If you are referring to the rubber cap over the main beam bulb it is best accessed through the hole in the wing in the engine compartment. (as detailed in the manual)
Did it last night to install my 100W main beams.
Any other access is as per Ian's suggestion.
Old Mar 9, 2007 | 03:32 AM
JPY's Avatar
JPY
Can you do something similar for the rear lights?
One of mine is badly misted.
Old Mar 9, 2007 | 03:44 AM
s2000tim's Avatar
Took the seal off about 3 days ago under Lloyds advice and it seems to be clearing
Hopefully it will completely clear in a few more days. If it does, RESULT!!!! Been annoying me for ages now.
Cheers Lloyd. U Da Man
