O2 sensor
Old Sep 5, 2006 | 12:19 PM
djpeak10's Avatar
Default O2 sensor
Ok I have done a search and cant find anything about this topic. Recently my 02 sensor went bad (secondary) and then i was hearing a rattle, took it to the muffler shop they said that it was my cat. So cat broke inside in turn broke my 02 sensor. I am going to pick a cat off a totaled S at a junkyard today. Is there a special tool i need to remove and put a 02 sensor in the cat? Because i want to get it done today and I want to be prepared. If i do need a tool where do i buy one?
Old Sep 5, 2006 | 12:35 PM
xviper's Avatar
I think they make O2 sensor wrenches, but to tell you the truth a large "Crescent" wrench is all you need. Give it a good SNAP to get it loose. Use a bit of anti-seize on the threads before putting it into the cat.
Old Sep 5, 2006 | 12:44 PM
jah's Avatar
jah
any tool will remove the 02 sensor.
goto autozone to buy a sensor there are 2 types, generic and an oem replacement. they are all the same so the dif between a oem and generic o2 sensor is the connector on the eom replacement will match the car.
with the generic you get a kit to crimp the old connector onto the new generic sensor. the o2 wires are stainless steel and you generally cant solder them.
Old Sep 5, 2006 | 02:00 PM
djpeak10's Avatar
Oh yeah one more thing will a cat off of a 2002 fit my 2001 because the junkyard has a totaled 2002
Old Sep 5, 2006 | 02:45 PM
xviper's Avatar
It'll fit.
Old Sep 5, 2006 | 06:37 PM
cdelena's Avatar
The Federal Emissions Warranty should cover the CAT for 8 years and 80K miles.
See this thread...
https://www.s2ki.com/forums/index.php?showt...0&#entry6021155
Old Sep 5, 2006 | 08:48 PM
djpeak10's Avatar
Yeah even vortech supercharged I guess i should check but it just seems pointless, because they look for any reason not to replace something
Old Sep 6, 2006 | 12:46 PM
r26372's Avatar
Don't go to Autozone, total ripoff for OEM and no need for kit. Got my O2 sensor from hondiscountparts.com, its a denso and I beleve $68 direct fit. Also some brand I never heard of for $43. Autozone wanted like $300 for sensor.
jimbo35ca
Sep 22, 2016 03:39 PM
jshimer23
Jul 7, 2011 03:40 PM
earri
May 2, 2008 01:30 PM
WarrenW
Mar 30, 2007 11:39 AM
nicku
Oct 2, 2006 05:54 PM
