CEL P0301 P0304 P0300
I have a MY2003, completely stock, with about 19,000 miles. Oil levels are ok. A couple days ago, I was driving around at low speeds for most of the day. I started to make another trip out, but a few minutes after I left my house the CEL turned on. I went to get the CEL codes pulled and got P0301, P0304, P0300. I checked the spark plugs and coil packs, but they all look to have similar wear and tear. Any advice on what I should check next?
misfires were on cylinders 1 and 4. i removed all 4 of the coil packs and spark plugs and visually compared them. i dont know if it's normal wear and tear, but they all appeared similar. nothing looked especially burnt, wet, or broken.
i could buy a code reader, swap parts around, reset the CEL, and try to narrow it down to what could be wrong. but i dont know if i would be damaging the car any, or if i will get the CEL again. or would it be advised to take it into a dealer/mechanic to get it checked out?
i reset the cel and drove around for a while. i drove lightly to warm up the car, and when i came to a dead stop at a light the car was a little rough and shaking for a second, clutch in, or out in neutral. no cel. after it warmed up, i didnt have this issue. i drove lightly, got into vtec for a little, and just put it through my normal driving conditions. i couldn't get a cel from any of this. there werent any abnormal sounds or vibrations that i could detect. the previous owner's maintenance records showed there was an intermittent misfire giving P0301 and P0303 about 5500 miles ago, but taken care of by the dealer. maybe it's a fluke? random misfire? flux capacitor?
CEL's aren't a fluke... Something's up...
My CEL went away for about 6 months when I changed my plugs, then came back as the same thing suddenly...
If not addressed properly, misfires can cause BIG headaches for ya...
I'd at least look into pulling injectors next...
i had a friend that's a former mechanic take a listen to it and he didnt hear any misfires tonight, so at least it's not a constantly happening. in the mean time i'm just listening for strange noises and feeling for odd vibrations. how'd you inspect the injectors?
