UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
Am going to view a couple of 04 s2000, and hoping to buy this w/end.
BUT... I freely admit to knowing bugger all about cars (other than how to drive...)
On going through the faqs, there was a great deal of detail about corrosion to the Suspension Wishbone & rear control arm bushes.
On just viewing the car (not on a ramp) and test driving it, is there any way to tell whether this problem exists? If so, could a knowledgable person explain it in language understandable by a noob please?
Fortunately am taking a mate who knows a thing or 2 about cars!
There isn't really a way of checking other than having the geo played around with.
Just lookout for general condition really, if the wishbones are really scaled up with rust then there will be more chance of seizing.
It doesn't seem to be a major common problem (i mean % wise) on these cars but its a pain in the wallet if you get one like it.
I'm fortunate enough to have bought new so the first thing i did was take all the wheels off and treat all the arms and bushes to a coat of waxoyl. I will continue to do this every year to make sure it doesn't happen on mine.
I have a mate that has just been looking for and Elan (newer version) and one of the major problems on them are rear suspension corrosion and can cost
No!
The chances are the wishbones will look corroded. This is not a problem.
The problem that the car suffers is that the suspension bushes and the adjusting bolts seize together. Again, this is only a problem if the alignment is out and needs to be corrected.
Most people that have this problem are most likely unaware.
Fixing the problem is *very* expensive unless you do as I did and get the parts from breakers and do the work yourself.
Looks like a case of buying the best car I can, and then taking a look. If they are all OK, I will waxoyl them, and if they are corroded then I shall have to see....
If most people are unaware, then perhaps leave it until such time as I become sensitive enough to the the handling of the car to discern that the alignment needs adjusting...
Great post Kobe. That is a really useful picture, and one that I reckon should be added to the FAQ I reckon. Although the pictures there are in greater detail, yours shows an overview of what to expect when the wheel is removed.
