Mark this thread as Sold
Build Motor Ready To Go!
Old Mar 5, 2003 | 06:31 PM
cjb80's Avatar
Default Build Motor Ready To Go!
I have gotten word from Mike Simon that he has a build motor ready to ship. The cost is $6800 + core, and includes:
Sleeved Block
9:1 Compression JE Pistons
Head polishing
Stainless Valves
Valve Retainers
Pauter Rods
Polished Crank
Valve Springs
Head Studs
Main Studs
Machined + Assembled
You may be thinking: "Why so much money!?". With out going in to too much history with Mike Simon, he has developed THE most powerful F20C motor that I have EVER heard of. He was making well in to the 900rwhp range by the time he ended his drag racing career.
I had located Mike Simon by stumbling across some people talking about him making rediculous power with the F20C motor. I called the dyno shop, and begged for his number. About a month later I got in contact with him...
He had dynoed at 730rwhp at 27psi, and later went to the track and ran much more boost, with nitrous. You can find pictures of his race car on my website. http://www.chrisdrivesafastcar.com/gallery...php?category=10
Back to the point, "why so much money?". If you've noticed there haven't been too many people making S2000 motors.... There are several unique things about this motor which aren't evident, even to those who have disassembled them. Mike Simon has developed his motor build for several years and has perfected it.
His motors are capable of handling anything you can throw at it, and it will hold together like a champ. Simply put, his product is compliation of the best parts, and the best experience out there for the F20C.
Several turbo S2000 users have purchased his motors and they have been running well. Personally speaking I am running over 400 rwhp with mine, and plan to extend that to the 500rwhp very shortly. (see my website for more info)
Please post any questions on the forum, and contact me for purchase information.
Thanks!
Chris
Old Mar 16, 2003 | 02:25 PM
OneInsaneS2000's Avatar
Just to get this straight. Are you saying that for $6500 he will give me the entire engine built?
Old Mar 16, 2003 | 02:28 PM
Wesmaster's Avatar
Yes, after you give him your existing full motor.
Old Mar 16, 2003 | 04:12 PM
jvils's Avatar
Chris, how much hp could be expected from this engine? I didn't see an estimate for it in your post.
thanks
And bring your car to one of the Chin Motorsports events at Sebring or Moroso so we can all drool over it!!
Old Mar 16, 2003 | 04:51 PM
Wesmaster's Avatar
The motor itself is going to make less horsepower than stock, because of the reduction in compression ratio. But, in combination with 20 PSI the motor will make over 450 HP at the crank.
Old Mar 16, 2003 | 07:28 PM
SuzukaS2K's Avatar
$6800 I hope I don't blow my motor with my UR kit.......so I don't have to go Mike Simmon route. If I do blow my motor I might give it a try.
Old Mar 18, 2003 | 12:06 AM
mynameisneo's Avatar
This might seem like a naive question - but where is the midpoint between engine compression ratio, and the amount of boost you can get. EG, if we used 10:1 compression, how much less HP could we push?
Old Mar 18, 2003 | 04:03 AM
cjb80's Avatar
The motor would make about 160 hp. Put a small turbo on it, and it would make about 375 hp. Put a medium turbo on it, and it will make about 420 hp. Put a big turbo on it, and hopfully it will make around 500 hp. Put a rediculous turbo on it, and it will make around 750 hp. Run nitrous and max out the rediculous turbo and you'll make around 900hp.
Mike's drag motor was running race fuel at 10:1 ratio.
Lowering the compression will allow you to run higher boost levels on pump gas.
Chris
Old Mar 18, 2003 | 05:35 AM
F1s2000's Avatar
And as for tuning what system can be used? And I'm assuming that type of motor will benefit from the vortech kit considering that blower can push up to 30 lbs.
Old Mar 18, 2003 | 07:33 AM
Wesmaster's Avatar
Originally posted by cjb80
...900hp..
I'll take two!
