Change your oil & filter from above the car, no tools!
Well, actually I plan to continue using a torque wrench to tighten the oil filter.
Look how you can reach the fumoto drain valve from above the car!
I am an Engineer and have thought through issues of beam vibration and galvanic corrosion, I do not feel these two concerns are significant. Mostly because of the reinforcement of the oil drain area, the gasket material used as a washer, the and the oil content excluding galvanic corrosion.
You'll see mine does not have the nipple. I prefer it this way. Plus without the nipple you can tighten the bolt with a 7mm hex key bit.
P.S. The adapter needs a 23mm box-end wrench, and the body can be turned with a 19mm open-end wrench, I found I could not get the 19mm on at a certain angle and had to put the 7mm key in the drain hole.
My valve lever ended up on the bottom of the valve, but I don't have any issues with oil dripping on it since I also bought one with the nipple. I would have to look up the old post to see when I originally put mine on, but i'm thinking it's been about a year now...no oil leaks so far, and I've been through a number of oil changes.
I snugged it up pretty well on the first install (actually the second since I snapped the adaptor threads off in my oil pan on the first attempt...damn, but brass is soft). I check it for hand tightness whenever I change the oil, and between that and seeing no leaks, I'm satisfied.
I have this setup and I love it! no problems so far! I opted no nipple as well - you can't beat a 10 minute oil change for just the price of oil and a filter!!!!
Don't try to torque to the full spec for the stock bolt which uses a crush washer. I only went to what felt like 3/4 that much, the 1/4 turn they recommend to tighten.
