Gauges / Boost / Temp...
Old Apr 4, 2001 | 06:14 PM
Wesmaster's Avatar
I got my gauges installed:
http://www.s2000online.com/forums/showthre...?threadid=10934
I just got the car back, and had some questions. The boost gauge, according to the installer is only going up to 5 lbs, which he thought the SC was making 8lbs - anyone else got a measure? On the Exhaust Temp, before I left he said that I should only get concerned if the exhaust temp went up to 1,200 or above; it was at 1,300 when driving slowly in 4th. I got up to 1,400 in 6th gear cruising at 85. Anyone else got gauges? What are your readings? Installer also recommended contacting Comptech to see what they have on their readings.
Wesmaster
[Edited by Wesmaster on 04-04-2001 at 09:06 PM]
Old Apr 4, 2001 | 11:44 PM
wileecoyote's Avatar
Wesmaster,
What is the unit of your exhaust temp gauge?
F or C?
1400C seems too high.
Old Apr 5, 2001 | 02:40 AM
turbo_pwr's Avatar
I believe the SC was suppose to put out 6psi. 1400 seems awfully high for that EGT. Running to rich or lean? what does the Air/Fuel show your at?
[Edited by turbo_pwr on 04-05-2001 at 03:43 AM]
Old Apr 5, 2001 | 05:26 AM
Wesmaster's Avatar
[QUOTE]Originally posted by turbo_pwr
[B]I believe the SC was suppose to put out 6psi.
Old Apr 5, 2001 | 06:36 AM
derryck's Avatar
I agree with turbo_pwr, your EGT's are very high. I know in my Eclipse ( I know it's not an S2000) that around 900 is the target range and if it read 1400 my Eclipse wouldn't be long for this world.
Old Apr 5, 2001 | 06:37 AM
Wesmaster's Avatar
I called the installer today. He said it's high, but not anything I should be scared about. He just said I needed to call Comptech and see what they say. He felt that they might recommend "bigger injectors".
Wesmaster
Old Apr 5, 2001 | 08:29 AM
turbo_pwr's Avatar
Wes, I strongly suggest you contact Mike at Comptech and check to see what they record on their car. Considering the low level of boost 5-6psi of the SC, I'd imagine that bigger injectors aren't necessary, especially if you state the car is in the rich section of the gauge at WOT. Not sure what is the temp at idle? Also would you mind taking a picture of where the sensors for the air/fuel and EGT are mounted/tapped.
Old Apr 5, 2001 | 09:21 AM
Wesmaster's Avatar
[B]Wes, I strongly suggest you contact Mike at Comptech and check to see what they record on their car.
Old Apr 6, 2001 | 07:28 AM
Wesmaster's Avatar
Here are the pics of the Exhaust Temp probe and the Air/Fuel sensors.
Exhaust Temp in #3 cylinder exhaust.
Air/Fuel in Green, Honda 02 sensor in Red.
Wesmaster
Old Apr 6, 2001 | 07:38 AM
RT's Avatar
RT
Wes, the red is intake air temp sensor, the green look like manifold pressure (boost).
