Honda OEM S-02 specs...finally!
Well the Tirerack finally has specs listed for our OEM tires (the info used to be blank). Notice our OEM rear tires are 0.4" wider than the Porsche OEM model even though the tires are both 225/50/16s -- and they were both measures on 7" rims. Also notice our OEM front tires are more narrow than the Porsche OEMs even though they are both 205/55/16s -- and the Honda OEM were even on wider rims!
Size.............................................. .UTQG......Inflation...Rim Width Range...Meas. Rim Width....Tread Width
205/55WR16 89W SL (Honda OE)...140 A A...44psi.......5.5-7.5".................6.5".......................7. 1"
205/55ZR16 N3 (Porsche OE)..........140 A A....44psi......5.5-7.5"..................6".........................7 .2"
225/50WR16 92W SL (Honda OE)...140 A A....44psi......6-8".......................7"....................... ..8.5"
225/50ZR16 N3 (Porsche OE)...........140 A A....44psi......6-8"......................7"........................ .8.1"
http://www.tirerack.com/tires/Spec.jsp?mak...el=Potenza+S-02
Originally posted by Unicron
That's right baby...the stock S02's are wider than my 245/35/18 Toyo T1-S's and they will be wider than some 255/35/18's also.
I just spoke with a Bridgestone Tire rep (the mfg not a dealer). He felt the current shortage of S-O2's was likely due to the fact they intend to discontinue it in favor of the new S-03 PP. I will try to get further confirmation from the factory reps at the Drive & Learn event this Friday. This would be a good time to get a set of S-O2's if you are partial to them.
Rim width affects tire width (cross section width) but not tread width (at least not appreciably).
Check out the tread width 205/55R16 for the Yokohama A032R
http://www.tirerack.com/tires/Spec.jsp?mak...ama&model=A032R
