2003SPA2000 Donated his single for the fitment!
Thanks James!!!!
This is a "cap" or "skin" that covers the matte black factory cutout when you run a single exhaust giving you a factory finished look to your rear bumper, the initial offering is made from ABS and has a factory finish. It is held in place with black 3m VHB to blend and two factory mounting points are also used, It is very light weight and durable.
These will be available at Ricks2k.com as soon as I have final pricing info!
These caps will mount with 3m VHB adhesive on the top edge and two pre-drilled mounting points under the bottom edge!
. Nick
ricosuave,
You are referring to this !
Please don't do this to me
I like the look but haven't even thought of doing that right now, I suppose if any of our European counterparts did a group buy, A separate mold could be made - remember that this is a cap to cover the stock piece on the bottom, it does not replace it. The bottom piece is molded to the bumper not bolted on. I hope that helps!
