I have the first Comptech aftercooler system on my S
I just got my S back from Comptech USA. Comptech used it for a shoot for Car and Driver Magazine. In return I now have the first aftercooler system from Comptech on my car. The car is great now. I'm able to run 11.2 in 1/4 mile with this new system. I just added a Godzilla Blowoff valve to make it have that wicked sound. I have not tuned my car yet with the Venom VCN nos kit, but I'm hoping to have it in the 10's with it. Let me know what you guys think.
Andrew
I'm guessing you were running your NO2 when you hit the 11.2, so what shot are you running? Also do you have any internal work done to the car? One last question, can you post the time slip of the 11.2 run? Thanks.
11.2 was with the aftercooler and high boost pully only. The car also has a 4.44 rear end which helped out. That run was done by Car and Driver and will be posted in there mag. There is no internal work done to the engine, but I'm considering ordering some 9 to 1 JE pistons.
I saw your car at the Comptech display at Sac2kdays. It is sooo nice! I personally liked it better with the Work wheels they were showing it with. Was the wing there when they were showing it? I don't remember it. Overall it's very nice. I'm glad the aftercooler is finally in production.
Originally posted by garciabailbonds 11.2 was with the aftercooler and high boost pully only. The car also has a 4.44 rear end which helped out. That run was done by Car and Driver and will be posted in there mag. There is no internal work done to the engine, but I'm considering ordering some 9 to 1 JE pistons.
Your list of Mods does not include 4.44 gears, but it does have other diff stuff. Do you have gears?
Sounds great! I'm assuming you use the blow off valve to enable a high boost pulley. This way you could make high boost at low RPM and the blow off valve you limit your boost at high RPM? What boost are you running at?
Nice setup! A couple questions I have about it. Do you know what size pulley you have on there and also how much boost you are producing? Do you know anything about when this setup will be released by Comptech?
