Clicking noise
Old Aug 10, 2003 | 07:44 AM
AquilaEagle's Avatar
Administrator
Default Clicking noise
Noticed a clicking noise this afternoon. When i pull off slowly or start reversing i get what sounds like 2 very quick click noises from where sounds like the rear o/s wheel area, like ball bearings hitting each other, but very faint noise. Anyone noticed this or know what it might be?
Old Aug 10, 2003 | 07:50 AM
Chris Type R's Avatar
[QUOTE]Originally posted by AquilaEagle
[B]Noticed a clicking noise this afternoon.
Old Aug 10, 2003 | 09:17 AM
Frisky's Avatar
Ian, I had this on mine not long before I sold it. It is the point where the drive shaft joins the hub, there are some splines on the shaft that shift about when then joint dries out. Not sure why it dries out but Guildford Honda took mine in for 1 hour, removed all the hub and greased it all - problem solved! They had one in a week before mine with the same problem so they knew what to do.
If your local dealer does not know what the problem is then get them to speak to the workshop manager/foreman at Guildford Honda, he knows all about it.
HTH,
- Adam.
Old Aug 10, 2003 | 11:51 AM
Administrator
Thanks guys - will try and get it investigated tuesday
Old Aug 14, 2003 | 05:06 AM
Administrator
Had it checked by crown honda today, they couldnt find the clicking noise and said if it persists come back. I get on the road and it isnt doing it. Half way back I pull off from traffic lights and click! how annoying. I can definately hear something, or am I being paranoid
Old Aug 14, 2003 | 05:13 AM
Coxyboy1's Avatar
[B]Had it checked by crown honda today, they couldnt find the clicking noise and said if it persists come back.
Old Aug 14, 2003 | 05:27 AM
Beno's Avatar
Mine does exactly the same...I'll get the boys to have a look
Old Aug 14, 2003 | 05:31 AM
SilverShark's Avatar
I'll also get it checked as mine does the same.
AE - I also go to Crown, do you have a technician there who is the only tech to work on your car ????
Old Aug 14, 2003 | 05:36 AM
zero_to60's Avatar
I seem to have all manner of noises coming from all over the place....I am assuming it's 'just the car'?
Old Aug 14, 2003 | 05:40 AM
Dracoro's Avatar
Reminds me when I mentioned that the clutch was slipping in traffic jams. Clutch worked fine when the dealers tested it so said it was OK no clutch (i.e. they didn't believe me?). Anyway is started to make the rattling sound soon after and they replaced it without fuss. I think they were a bit red faced after thinking I was 'trying it on' to get a free clutch.
I also always get their senior mechanic working on my car too which is thumbs up!
