What would it take to get the Euro-spec rear fog light onto our cars?
Old Aug 12, 2003 | 06:01 PM
s2kdriver80's Avatar
Default What would it take to get the Euro-spec rear fog light onto our cars?
Has anyone tried this on their USDM S2000s? What would it take (the easiest way) to mount the fog light onto the rear black diffuser piece? I guess the simplest way would be to somehow get the entire black diffuser (with the fog light in it) and attach it to the bottom of the car and wire it up to a switch inside.
Old Aug 12, 2003 | 07:11 PM
speed4tu's Avatar
[QUOTE]Originally posted by SiDriver
[B]Has anyone tried this on their USDM S2000s?
Old Aug 12, 2003 | 07:35 PM
Yea I could cut a hole but it would look hacked and would not look clean. I guess if one were to do this, they should just get the entire rear bumper piece.
Old Aug 12, 2003 | 10:23 PM
revLIMITLESS's Avatar
Someone on the board has already executed this mod/conversion.
I am sorry I do not remember who but you may want to do a search.
-trung.
Old Aug 13, 2003 | 04:37 AM
Bass's Avatar
not true at all as Darknight1999, GS2k and I did it on my car - yes you have to remove the rear bumber (not a big deal) and then inside the bumber there is an imprint or template that shows exactly where to dremmal the hole out (start by cutting the hold a little smaller than the line).
i ran the wires to my center console and modified a rear defrost switch for the 00 - 01 to turn the light on.. Boy is it bright here's a picture of the completed project.
[/B][/QUOTE]
Old Aug 13, 2003 | 05:22 AM
TrueDrezzer's Avatar
on Euro cars, the fog light switch is behind the wheel on the left side, right where the cruise control would be on US cars I believe.
Yes it is bright I've only had to use the sucker 3-4 times so far.
///Robin
Old Aug 13, 2003 | 05:29 AM
my2k2s2000's Avatar
[/B][/QUOTE]
just out of curiosity... why choose a red color if it's a rear fog light?
Bass's Avatar
you are 100% correct Truedrezzer - hence the reason i used a rear window defrost switch (right behind the cup holder)
my2k2s2000 - the reason for red color is because a white light would blind the folks behind you..
the sole reason for the ERO fog light is because it helps drivers behind you see you in heavy fog - now we really don't have this problem in the States BUT it still helps - i use mine during the holidays (worried about drunk drivers hitting me from the rear) and when some one is tailing too close
Old Aug 13, 2003 | 06:03 AM
PLYRS 3's Avatar
bass,
how much $ were the parts???
are/would the required parts be available in the US/Canada?
Old Aug 13, 2003 | 06:12 AM
Bass's Avatar
The parts came as a gift from a close friend. she picked it up while traveling back home to Germany over the holidays
don't think you can order them here but the UK guys might be able to help..
here's a few good posts
https://www.s2ki.com/forums/showthread.php?...r%20fog%20light
and prices and part numbers - all you need is the lamp assy
hope this helps
