rear wheel dolly instead of flatbed tow?
Old Sep 25, 2003 | 12:50 PM
STL's Avatar
STL
Default rear wheel dolly instead of flatbed tow?
Is that okay?
Old Sep 25, 2003 | 01:22 PM
Feezy's Avatar
NO!
Old Sep 25, 2003 | 01:24 PM
STL's Avatar
STL
Originally posted by ROLLININMYS2000
NO!
Why? It is already on one...
Old Sep 25, 2003 | 01:25 PM
STL's Avatar
STL
FYI, I would do a search but the search engine here appears broken.
Old Sep 25, 2003 | 01:56 PM
Chazmo's Avatar
[QUOTE]Originally posted by STL
Why?
Old Sep 25, 2003 | 02:02 PM
STL's Avatar
STL
The guy answered "NO!" when I asked about using a rear wheel dolly instead of a flat-bed tow so I asked "Why?". Then I stated that the car is already on them. My wife, who wrecked the car (but it wasn't her fault), told them she needed a flat-bed tow but they sent a regular truck with some dolly to put under the rear wheels. I'm hoping that is okay -- but if not I want to know why (so I can understand what, if any, damage was done).
Old Sep 25, 2003 | 02:15 PM
slalom44's Avatar
Top Answer: 1
If the front tires are up on dollies, you may be fine. If not, you're certain to scrape the front bumper bottom. There may be some other issues that I'm not aware of.
Old Sep 25, 2003 | 02:19 PM
slalom44's Avatar
Top Answer: 1
Oops, my mistake. You have the dollies under the rear wheels, and presumably you have the front end lifted.
This may be OK, but I don't think the tow bolt was designed to take that much force, and you could risk bending the bolt, or the frame where it attaches. If it's already been done, check out the tow bolt fitting to see if there was any damage. Otherwise, there shouldn't be any problems.
Old Sep 25, 2003 | 02:28 PM
STL's Avatar
STL
From talking to my wife, the guy didn't use the tow bolt at all. I assume the truck is holding the front wheels somehow and the rears are on a dolly. Man I sure hope nothing else gets damaged.
Old Sep 25, 2003 | 04:03 PM
cdelena's Avatar
As long as the rear wheels are not turned and nothing is scraping it is fine.. more than one way to do almost everything.
