32/32 psi balance between comfort/perf and 42/42 psi less than optimal traction .....
Old Nov 22, 2003 | 08:35 PM
s2kdriver80's Avatar
Default 32/32 psi balance between comfort/perf and 42/42 psi less than optimal traction .....
The manual states the recommended tire pressures of 32/32 front and rear probably for balance between comfort and performance. I've been riding on 42/42 but people have said it is way too high and that it actually decreases traction. What air pressures would provide the optimal spirited handling performance (I'm probably assuming between 32 and 42 psi) for the S2000? And another question - what air pressures would be optimal for use during inclement weather (rain/snow)? Thanks.
Old Nov 22, 2003 | 09:13 PM
allkingz's Avatar
I believe tire pressures are calculated according to safety and mileage.
Also, if you overinflate tires, the tires are more likely to be cut, punctured, or broken by sudden impact.
Old Nov 22, 2003 | 09:51 PM
steve c's Avatar
Cold or hot?
I have seen well over 42 hot on the track (stock S02's) with no issues.
Old Nov 22, 2003 | 10:20 PM
Mindcore's Avatar
I run 36 front 38 rear.. its sharper then stock, but doesn't wear out the tires much faster then 32..
I notice a definate improvement in grip with these pressures
Old Nov 23, 2003 | 04:42 AM
jguerdat's Avatar
42 psi cold is too high. Autocrossers on S02s have suggested 38f/34r or thereabouts. I'd definitely lower the pressures and play around with the lower settings to figure out what works best for you.
Old Nov 23, 2003 | 07:49 AM
honpar's Avatar
32 p.s.i. all round should give you the optimum footprint for the tyre. Upping the tyre pressures will not only change this footprint, thus giving less grip, but will also dramatically increase your wear rate. Stick to the recommended pressures, it's safer and cheaper!!
Old Nov 23, 2003 | 08:22 AM
amongmany's Avatar
Interesting that in three posts there have been three completely different views:
1. rear higher than front, both higher than 32
2. front higher than rear, both higher than 32
3. 32 all the way around or bust
I'm interested in seeing how this pans out!
Old Nov 23, 2003 | 12:30 PM
RazorV3's Avatar
32-33 psi (for all 4 tires) for me, works great so far.
i personally would not make the rear have more air pressure than the fronts since it 'll make it more prone to oversteer, and we all know the s2000 is known for its snap oversteer.
Old Nov 23, 2003 | 12:47 PM
jyeung528's Avatar
Originally posted by RazorV3
32-33 psi front/rear for me, works great so far.
...but your rear does have more air pressure than the fronts..
Old Nov 23, 2003 | 12:48 PM
jyeung528's Avatar
oh...i'm running 36 front, 37 rear cold measurements...boy i get a lot of oversteer...i keep forgetting to lower it.
