Ahhh There Really Are Benefits To Those Ricey Hoods & Vents...
A fellow friend and BMW owner, Gustave, who's also a Phd in Fluid Mechanics, had this to write...
"Some of you may hear me go on about hood vents and wonder what the heck I'm talking about.
Here's a picture from test data in a wind tunnel that quite descriptively shows why you might want to place a hood vent near the front of the hood, not near the back.
The length of the arrows represents the local lift coefficient, either positive (into the vehicle surface) or negative (away from the vehicle surface).
Note the very high lift near the front of the hood where the flow turns the corner. This translates to negative pressure in this area. Similarly, near the rear of the hood, the cowl, we high positive pressure, which is why all production cars have inlets for their HVAC systems in this region.
Just FYI type of stuff..."
Gustave
Gustave
If I read that image correctly, then, the cowl does not need to stand into the wind, but merely have an open hole near the front and rear of the hood. A cowling of any sort would seem to screw up the airflow since the data points are mentioned as normal vectors to the hood surface.
[QUOTE]Originally posted by wantone
