Changing Brake Fluid & Clutch
Old Jun 8, 2001 | 01:41 PM
Tanqueray's Avatar
I intend to change out my brake fluid next week to Motul, and I have a handle on the procedure involved. It seems to me that I am leaving the original break fluid in the clutch lines and slave cylinder; can this get back into the brake system and pollute my new, high temperature brake fluid?
Also, do I ever need to bleed the clutch?
Thanks for any info.
Old Jun 8, 2001 | 01:50 PM
Pepe's Avatar
[QUOTE]Originally posted by Tanqueray
[B]I intend to change out my brake fluid next week to Motul, and I have a handle on the procedure involved.
Old Jun 8, 2001 | 01:51 PM
Prolene's Avatar
[B]I intend to change out my brake fluid next week to Motul...
RT's Avatar
RT
Two systems are independent. Uses the same fluid type but completely separate circuits.
Clutch fluid is not normally subjected to the same heat as brake fluid but still needs freshening because of moisture (hydroscopic fluid)........ but probably not as often.
Old Jun 8, 2001 | 01:53 PM
Tanqueray's Avatar
Thanks for the help, guys -- 3 replies in 10 minutes!
TheLast13
Feb 11, 2011 04:36 PM
S2KNJ
Jun 5, 2008 12:18 PM
bunjimobile
Oct 18, 2004 08:12 PM
