just installed alarm, need help
Old Jan 5, 2004 | 01:08 PM
dmpts2k's Avatar
Default just installed alarm, need help
well i hooked up a clifford alarm, and everything works except for the fact that i cant get the power door locks to work. i tested the solenoid box and all the wires and i still couldnt figure it out. the only thing that i could figure out is how to unlock the door but not to lock it, and the only way that would work is if the driver door was unlocked. IF YOU KNOW ANYTHING ABOUT THIS PROBLEM PLEASE PM. THANKS
Old Jan 7, 2004 | 07:21 PM
ruexp67's Avatar
Well, my alarm was installed by an audio shop, but I do know they struggled with the same issue. They ended up calling the alarm company for help. It required multiple relays.
Old Jan 7, 2004 | 08:07 PM
LowBudgetS2K's Avatar
double check if u got the right wires. if the wires are testing just make sure they are not the lock motor wires. im pretty sure u got the lock motor wires. they will only work if u dont lock or unlock the doors. if u still cant find the right wires just pm me i can get u the wire colors when i get to work.
Old Jan 11, 2004 | 01:54 PM
bobby's Avatar
WIRING INFORMATION - HONDA / S2000 / 2001 / Remote Start
[PRINT THIS PAGE]
12volts white (x2) + ignition harness
Starter blue/white + L of column, lt blu 24P plug
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition black/red + ignition harness
Third Ignition N/A
Accessory white/red + ignition harness
Second Accessory N/A
Keysense red/white - ignition harness
Power Lock pink/black 5wi keyless entry module
Notes: The keyless entry module is located in the driver kick behind the start button.
Power Unlock yellow/green & pink/blue 5wi keyless entry module
Lock Motor pink/black 5wi keyless entry module
Unlock Motor yellow/green 5wi keyless entry module
Parking Lights+ red/black + keyless entry module
Parking Lights- blue - headlight switch
Hazards same as turn signals
Turn Signal(L) green/red + steering column
Turn Signal
Old Jan 11, 2004 | 02:13 PM
bobby's Avatar
go here for diagrams http://www.the12volt.com/doorlocks/page3.asp#5wrams
yorkies2k
May 12, 2014 02:36 PM
S2KCHRIS305
Aug 15, 2012 10:05 AM
splatter85
Jun 17, 2009 08:08 PM
dmpts2k
Jan 5, 2004 12:37 AM
Kwando
Apr 2, 2001 10:32 AM
