If you own an S2000 - especially new owners - READ THIS - it may save your life
1.) The stock S2000 tires (read: ALL high performance summer tires) are no good below 40 degrees Farenheit. You will have little to no traction as they freeze/harden up and they WILL NOT WORK IN SNOW. If you expect to drive your car in cold wet and/or snowy weather - change your tires to some dedicated snows or at least good all seasons for the colder months.
2.) When you first take delivery of your car - always check for the spring spacers on all 4 corners. They are there to ensure a higher ride height during shipping/transportation - but if left in they will cause the car to snap oversteer at the slightest turn and/or throttle input on a corner. Jack up the car and look for the rubber spacers that sit in the coils of each spring - check all the way around as some of the spacers are in the back of the coil out of sight.
This should be a sticky at the top of the forum. There have been WAY too many people crashing their cars (some fatally) in cold weather and sliding around with their spacers still in... Maybe if all new S owners read this then our insurance rates won't continue to climb and more importantly - we won't lose any more members.
Be safe!
Be safe!
Originally posted by rogerio1234
Old but VALUABLE info.
