California - Southern California S2000 Owners Southern California S2000 Owners
I need more views...
Old Jan 14, 2004 | 04:17 PM
Roku_F20C's Avatar
Default I need more views...
did you guys see this thread
http://forums.s2ki.com/forums/search.php?s...rder=descending
Old Jan 14, 2004 | 06:11 PM
AP1ByDesign's Avatar
Quote by Roku_F20C:
It is on the side of the intake cam...
100 shot is not gonna hurt the engine..just like a turbo making 100 more hp will hurt the engine
_______________________________________________
Here is my view on nitrous...If you are going to do it...do it right. You got a single nozzle dry setup. Now, if you plum the single fogger in the intake, that means the nitrous will go through the throttle boddy, then once it reaches the intake manifold, the nitrous has to be divided between the (4) runners on the intake manifold. The problem with this is the nitrous will not get distributed evenly between the (4) cylinders. This will cause uneven fuel atomization along with each cylinder getting different amounts of nitrous. Not good....you will probably lean out and burn a hole in 1 of the 4 of the pistons.
If you go wet ...you are injecting the fuel and nitrous together, which atomizes much better which will ignite much more efficiently.
The best way, IMO, is direct port. You are injecting an EQUAL amount of fuel and an EQUAL amount of Nitrous into EACH of the cylinders.
My recomendation, get a direct port system, and don't run 100shot, do a 60-75shot!!!
My $.02
Old Jan 14, 2004 | 06:16 PM
btw,
Let me know if you have any questions or need some help.
Nitrous used to be my friend, but then I started replacing my motors...
Old Jan 14, 2004 | 06:17 PM
Roku_F20C's Avatar
read the thread again...
Old Jan 14, 2004 | 08:20 PM
Ro_Ja Boy's Avatar
read this thread. Answer all your Nitrous ?s! http://forums.s2ki.com/forums/showthread.p...threadid=158407
Old Jan 14, 2004 | 08:30 PM
Roku_F20C's Avatar
read the thread again....
Old Jan 14, 2004 | 08:42 PM
wicky's Avatar
you put it in the VALVE COVER???
damn rufio, you are a bozo!
Old Jan 14, 2004 | 08:43 PM
wicky's Avatar
you need to read up on Nitrous. Go here: http://www.resort.com/~banshee/Info/N2O/N2O.html
Old Jan 14, 2004 | 08:45 PM
alexf20c's Avatar
This should also be rather helpful:
NOS Tutorials and Troubleshooting
Old Jan 14, 2004 | 08:57 PM
Roku_F20C's Avatar
very helpful
