Low Profile Floor Jack
I am looking to a reasonble priced low profile floor jack.
My current jack stands about 5" tall when lowered completely, and currently it just *BARELY* fits under the side jack points. Someday I plan to lower the car some. So I am looking for a lower profile jack.
I have had the same problem. I solved it by making some ramps from 2"x12" lumber which give the vehicle enough elevation to get a jack under the front spoiler for example. I have other ramps which do not work because of the front spoiler.
I also made a ramp using 2x12 lumber in order to get my floor jack underneath the front. It worked pretty well. Here's a picture:
Since then I saw a set of plastic ramps called Jackramps at an autocross and I bought those. Here's a picture of this ramp:
Dimensions are 24" long by 7" wide. Height is 2" for the lower step and 3" for the upper step. Cost was $40.00 + shipping from Protech Products, 405 S. Victory Blvd., Burbank, CA, 91502, 818-558-1146. No Web site a couple of months ago, may have one now.
However, I've also seen a similar plastic ramp at Griot's Garage which cost $45.00, but they have a "stopper" similar to the one that I made for my wooden ramps.
Krazik:
I went to Costco and picked up a 2 ton floorjack. guess what? It fits perfectly when you remove the "extra" pad. If you want to check it out, just come on by sometime. If you'll recall, I brought it to the track day at Thunderhill and we never used it.
I found this jack when I had my Pantera. It is also an extremely low car.
I think this jack cost me all of $40.
I think it's time to llok into those expensive, light jacks racing tems use available from BSR and other race suppliers. these are low, light but will cost you a lot, at least more than the Costco unit.
