Neo, GM syncromesh, Redline...
Old Feb 16, 2004 | 08:08 AM
YellowSSM's Avatar
Default Neo, GM syncromesh, Redline...
Which transmission fluid do you like better and why?
Old Feb 16, 2004 | 08:10 AM
Road Rage's Avatar
All these have been discussed at length - see some of my post or search on topic. I do not consider NEO fit for our cars, as its specs are absurdly low in viscosity.
Old Feb 16, 2004 | 08:27 AM
pfb's Avatar
pfb
It really depends so heavily on your usage and the typical ambient temperatures...
Stock Honda fluid works great for a little while, but seems to fall apart when it is older, especially on really hot days at the track.
Red line MTL is a little thin, Red Line MT-90 is a little thick. If you are doing a bunch of track work and the climate is hot, I think MT-90 is a good solution. Mixing MT-90 and MTL 50/50 is an option for street use and occasional track, but the shifting will be stiff when cold.
No experience with Neo...
As mentioned above, a search will give you lots more opinions, some of the threads might also be in racing & competition, can't recall.
GM syncromesh didn't do anything for me, and I likely wouldn't opt to use it again.
Old Feb 16, 2004 | 08:41 AM
Gernby's Avatar
I've tried many of them.
https://www.s2ki.com/forums/showthread.php?...threadid=182485
Old Feb 16, 2004 | 10:48 AM
honda606's Avatar
Redline MT-90 for me here in Texas.
Old Feb 16, 2004 | 10:52 AM
heffergm's Avatar
I find Honda MTF to be perfectly acceptable here in VA where the temp varies quite a bit year round (90+ in summer, sub freezing in winter). It's a little notchy in the cold (but if you can show me a manual that isn't when it's 20F out, I'd be surprised), and once it warms up it's great.
Old Feb 16, 2004 | 11:18 AM
Gernby's Avatar
How much time do you spend on the track in the summer?
Old Feb 16, 2004 | 11:17 PM
vapors2k's Avatar
I've had the same results, very happy with honda mtf. I know it's time for a change when it gets notchy when cold, I've been running the same tranny fluid for over a year now with many track events and have not grinded any gears.
Old Feb 17, 2004 | 05:35 PM
RazorV3's Avatar
its perfect for a daily driver with few track sessions. i plan on changing the fluid out once a year. honda mtf feels much better when COLD than HOT, it seems the opposite is true for other fluids for some reason.
Old Feb 17, 2004 | 06:20 PM
Gernby's Avatar
I think the important thing is that some trannys like some fluids more than others. For my tranny, Honda MTF was shit. Of the 5 fluids I tried, it was the worst by far on the street or track. The only way I could go a single day without grinding into a gear was to not drive. Urine might have worked better.
