[I]Gear[/I] heads- 4.77 final install options
Old Feb 20, 2004 | 09:25 AM
PrimoAP1's Avatar
Default [I]Gear[/I] heads- 4.77 final install options
So i have decided to opt for the 4.77 and have it installed locally at a shop I trust- that builds American race cars. They have a master tech/ machinist that only works on diffs.
So when talking to the guy about doing the work, he asked if there were any other things I wanted to do while we had pumpkin down... He asked me if there were any tolerances to be had in the limited slip such as adding a disk to strengthen it up or in the gears to lighten anything- not sure if he meant literally
So I need your help guys! Is there any other modifications or add ons or fix- its I should do while swapping my final gear?
Thanks in advance!
Old Feb 20, 2004 | 09:28 AM
Luder94's Avatar
Replace the '02 pumpkin with an '04.
Old Feb 20, 2004 | 09:59 AM
PrimoAP1's Avatar
That has to be quite costly don't you think... There has to be a cost to benefit ratio too
Old Feb 20, 2004 | 10:31 AM
wortham's Avatar
the diff is one of the weaker points in the car. if you're running FI, changing out gears, or otherwise drive your car hard, i'd suggest getting your hands on a reinforced differential. it may save you some trouble down the road. i bought mine from rick's for $399 plus the core charge.
Old Feb 20, 2004 | 10:47 AM
xviper's Avatar
Does he have ALL the installation calibration specs. If not, you need to give him a copy of that part of the Helm manual. If he does this with similar specs to what's he's been used to (American diffs), you may be in for some interesting noises once he's done.
Old Feb 20, 2004 | 12:51 PM
PrimoAP1's Avatar
Does anyone have the specs for his? He did ask for them... What about tolerances can things be adjusted or strengthened in anyway.
Old Feb 20, 2004 | 01:10 PM
Gernby's Avatar
Recently, there has been a lot of debate about the "proper" backlash spec for aftermarket gears. The concensous seems to be that the 4.10s need less backlash than the 4.57s (and probably 4.77s), so the American specs might be better. Honda's OEM specs are much tighter than the average Mustang, but the recommended specs for the 4.57s seem to be pretty close to the Mustang's.
Old Feb 20, 2004 | 01:12 PM
Gernby's Avatar
BTW, the Torsen differential is non-serviceable, and non-adjustable. The only adjustable specs are preload on the pinion and Torsen bearings, backlash between the ring and pinion, and contact pattern between the ring and pinion.
Old Feb 20, 2004 | 02:05 PM
xviper's Avatar
There are a LOT of numbers to do this job right. You really should have a Helm manual and all the proper instructions. Not having this is taking a bit of a gamble.
Old Feb 20, 2004 | 02:15 PM
PrimoAP1's Avatar
Where can I get the Helm?
Does anyone have the ROM they can burn...
Isee some guys have printed ones on EBAY- any thoughts to these?
