Cracked Toda Header bracket
Old Feb 29, 2004 | 07:39 PM
Slows2k's Avatar
My car developed a metallic rattle at 4100rpm. The tab the mounts the bracket to the block cracked. The header has been on the car about a year, (7000miles) I have not called AKH about the problem. For all you Toda owners, check your header.
Old Feb 29, 2004 | 10:07 PM
xviper's Avatar
Thanks, will keep an eye on it.
Old Mar 1, 2004 | 09:25 AM
beroznikmal's Avatar
Do you think that is might be due to the extra vibration that the SC contributes to the engine????
Old Mar 1, 2004 | 09:30 AM
Luder94's Avatar
If I'm not mistaken, the 1st gen Mugen headers suffered from the same thing.
Old Mar 1, 2004 | 09:34 AM
GDPzS2000's Avatar
wow, will keep an eye out as well
Old Mar 1, 2004 | 11:14 AM
bigpurp's Avatar
Thx for the heads up, slow. Let us know how AKH handles the issue.
Old Mar 1, 2004 | 02:26 PM
Slows2k's Avatar
I wouldn't go blaming the SC, It's only been on the car 3 months and 4000 miles. The bracket on the Toda is about 1/3 the thickness of the original. I would suspect material thickness being insufficient being the most likely cause.
Old Mar 1, 2004 | 02:43 PM
Slows2k's Avatar
I have contacted AKH, and e-mailed them pics. I'll post back if this is resolved.
Old Mar 1, 2004 | 02:59 PM
honda9krpm's Avatar
I hope you don't take this the bad way, but is this the problem rather than detonation or are they 2 separate issues?
Old Mar 1, 2004 | 03:05 PM
Slows2k's Avatar
2 seperate issues, The detonation has stopped after re-mapping the Split second timing controller and adding an additional 3 degrees of timing retard.
