look at this horrible fitment.... stupid REPLICA!!!..
Old Apr 6, 2004 | 08:18 PM
CeleSaga83's Avatar
Installed replica amuse lip today... result was . Big gaps between the lip and the front bumper....
Left.
Right.
not too noticeable from the front or side.. but once you get close to it.. it just pops out..
did anyone have such problems w/ their amuse lips?
Old Apr 6, 2004 | 08:36 PM
Chitah831's Avatar
you didn't expect it to be perfect did you?
There are ways to get it to fit I'm sure.... goodluck
And yes I've seen others with this problem in the same exact place.
Old Apr 6, 2004 | 08:37 PM
AusS2000's Avatar
Who makes that replica?
Old Apr 6, 2004 | 08:38 PM
Shinji's Avatar
Ya I had a replica Amuse lip also. It wasn't as bad as that but everyone that saw it noticed the gap. JL9000 has the authentic Amuse lip and it fits perfect with no gap at all.
You can also try dremeling the lip and try to shift it backwards.
Old Apr 6, 2004 | 08:45 PM
CeleSaga83's Avatar
bought it from ebay..
he is always selling amuse replica lips on ebay..
...www*jfracing*com is the ebay ID..
watch out..
Old Apr 6, 2004 | 08:48 PM
efthimios's Avatar
honestly...you knew you were buying a replica, and off of ebay to boot....what did you expect.......but to remedy your situation...some here have filled the gap with silicon to make the gap less noticeable by filling the void.
Old Apr 6, 2004 | 09:19 PM
t.c.'s Avatar
That's too bad for you buddy.
For me, replica is finish, i had too many annoying thing about that.
I bought OEM lip 2 years ago and it fitted and still fit perfectly.
Old Apr 7, 2004 | 12:25 AM
ahbongkadah's Avatar
i had this same problem with my lip, actually the gap was bigger.. i closed the gap almost completely.
What I did was take out the screw that mounts into the rear of the bumper (in the wheel well) and place lots of thick washers in there, you may need a longer screw as well. On mine i used a very thick rubber washer. Hope it works for you
Old Apr 7, 2004 | 02:50 AM
Saud2k's Avatar
i closed the gap, and now it barely noticable...you cant see the gap in pics
is im happy with mine
try going to a local body shop to help you tighten it up
Old Apr 7, 2004 | 04:31 AM
Russ's Avatar
I think most of the replica Amuse lips have this gap, some worse than others. I've
had two replicas from Spugen and both have a slight gap but it could be remedied
with one quick visit to a body shop for a morphing session but for the most part,
was reduced by manipulating the mounting bolts to ease the tension. If you raise
the lip too high, it seems to create that gap whereas I lowered mine and removed
some of the tension in that area and it seemed to create a tighter fit.
Unfortunately, the authentic AMUSE lip has also left gaps so go figure.
