Sticker installation
The visors stickers have now all shipped. Here's how to install them.
Four stickers are in each set, enough to cover the small and large labels on each visor.
Installation is simple. Remove the visors from the car and take them inside to a clean, padded (a towel will do) work space. Make sure the airbag warning labels are clean and free of lint.
Before mounting the new stickers, make sure your hands are clean. Because they are easier, start with the small stickers first. Gently pull the sticker up from the backing paper and carefull align one of the horizontal edges, making sure the corners are also lined up. Then gently rub the sticker back, working horizontally across the sticker a small amount at a time. Rub the sticker very gently at first, then after it is aligned, go back to rub out any wrinkles or bubbles and adhere the sticker firmly.
If you work carefully, you should not have a problem
Visor stickers, are put over the unsightly air bag warning sticker on your sun visor. Also the sticker has the S2000 logo on it
[This message has been edited by charlie (edited December 05, 2000).]
the only good thing about winter.
