Project Caliper now complete.... G2 painted caliper write-up and install
Old May 24, 2004 | 10:59 AM
Jason B's Avatar
This Project took me about 3 days total. This mod is not difficult, but is a little time consuming and tedious if you want to ensure a quality job.
Some have chosen to grind down the casting marks on their calipers before the G2 system and others have not. It looks good either way and is a personal preference. It all depends on how much time you want to spend. If you want your calipers to look smoother like a profressional powder coat job, then you should grind. Grinding will give you that "Porsche" smooth factory caliper look.
The materials used are as follows:
- G2 caliper paint kit. Red = $31.00 on sale (www.decalgirl.com)
- Bright silver metallic "S2000" logos = $11.99 (www.decalgirl.com)
- 2 3/4' wide Artist brushes = $2.99 each (Ben Franklin crafts store)
- 1 small pointed Artist brush (for more detailed/hard to reach areas) = $2.99 (Ben Franklin crafts store)
- 1 Sunday edition Hbg Patriot Newspaper = .50 cents (QT)
- 2 Hefty Trash Bags = .05 Cents (Walmart)
- 1 Dremel #953 Alum. Ox. Grinding Stone = $3.95 (Home Depot)
- 1 Dremel #932 Alum. Ox. Grinding Stone = $3.95 (Home Depot)
- 1 BrakeKleen Brake Cleaner = $0.00 (Included in G2 caliper paint kit)
- 5ft. standard Masking Tape from your basement = Free
Tools used/optional
- Die grinder with wheel. This is a fast and easy way to remove those casting marks in SECONDS! You need to be very careful if you use this tool because if you press too hard, you can ding the metal. If you don't have one of these, then the Dreme grinding stones will do the same job, but will take longer. (borrowed from neighbor).
- Generic dremel tool. = $9.99 with 60 attachements. (Harbor Freight)
- Sanding drums- came in the 60 piece attachment kit above, fit any hand/dremel tool.
Safety
- WEAR GOGGLEs and a MASK when grinding! You don't need metal fragments in your eye or in your mouth!
PICTURES!PICTURES!PICTURES!PICTURES!PICTURES!
First, get your car up on jackstands. For best way to get your car up on jackstands, read the 2nd post here
Picture of my front caliper FULLY grinded down in all visible areas and smooth as glass. (5+ hours total for all four calipers over two days.
I put about 6 coats of G2 on the fronts and 4 on the rear. Instead of mixing the full amount of paint and reactor in one shot, I took 4 parts of paint using a plastic spoon, and 1 part reactor on a spoon into a small can. This small amount let me do 1 coat on all 4 calipers. I then, repeated the above until I got mutiple coats. I probably have enough left over to do one more coat on all the calipers. I'll save it for touch up down the road. If you mix it all at once like the instructions say, you will only have about 3 hours working time before the paint is hard and unusable.
Picture before logos:
Picture after front logos:
I did not put logos on the rear. To my eye, it didn't really look as balanced and I only favor them on the front - they look like they are made to go there....
Some full shots:
A big thanks to StknCaS2k, Virus, enzyme, Hockey, ruexp67, Johnny--2K, KenGPW, and others
Old May 24, 2004 | 11:58 AM
PJK3's Avatar
very nice!
Old May 24, 2004 | 12:21 PM
Hockey's Avatar
Wonderful job!
That last pic of the wheel looks like my avatar!
Old May 24, 2004 | 02:56 PM
ideugene's Avatar
damnnnn... it looks realllll smooth!
Old May 24, 2004 | 03:27 PM
JerseyGirl's Avatar
They came out looking great!
Nice job! Very professional looking.
Want to come do mine? Pleeeeeeeeeeeeeeeeeeeeeeease!
Old May 24, 2004 | 05:31 PM
dt49396's Avatar
Thats a nice job. Looks better than the ones that are just sprayed over the raw caliper. By smoothing and polishing the caliper it gave it a look of a high end machined piece. Never really liked the sprayed calipers before, but I give you credit those look nice.
Old May 25, 2004 | 05:03 AM
speed4tu's Avatar
Great job, so smooth.
Old May 25, 2004 | 05:15 AM
KeithD's Avatar
Looks nice but don't track your car. You'll burn that stuff right off...
Old May 25, 2004 | 05:49 AM
2000celicaspeed's Avatar
how hard is it to get the calipers that smooth?
Old May 25, 2004 | 06:22 AM
Hockey's Avatar
[QUOTE]Originally posted by KeithD
