Real Men Destroy Their Brakes!
Old May 29, 2004 | 01:09 AM
KrazyKarim's Avatar
Pics of Jerry Peterson's "manly men" brakes from Buttonwillow. I'll let Jerry, Dave, Rylan, or someone else explain since they'd probably do a better job than me. I just have the pics
KrazyKarim's Avatar
Old May 29, 2004 | 05:24 AM
ImportSport's Avatar
Oh, wow....
Shocked and sad for him at the same time. Thats going to be a pricey repair. I had both of my front brakes smoking on the last dragon ball and I was worried. I dont even think my brakes would have accepted pedal input to get themselves in that condition.
Old May 29, 2004 | 05:26 AM
cdelena's Avatar
Some guidelines to avoid that kind of damage:
1) Use track compounds on the track.
2) Check pads before each session making sure you have more than 1/8" left before you pull to the grid.
3) Pit and check brakes when you find it takes increasing pedal pressure to slow the car.
It is dangerous for you and everyone else on the track to be driving at speed with equipment in that shape.
Old May 29, 2004 | 08:29 AM
twohoos's Avatar
So what's the story here? Never seen damage like that.
Will Jerry still be at Big Willow?
Old May 29, 2004 | 08:41 AM
krazik's Avatar
Administrator
chris: he was using track pads. He just didn't change them on time. If you've ever run to back plates its actually pretty hard to tell you're on them as braking still works very well. I want solid iron pads
2hoos: Yeah he'll be there. he just needs to rebuld the calipers.
Old May 29, 2004 | 08:51 AM
The Unabageler's Avatar
i've done similar before, split my rotor right in half! very exciting
Old May 29, 2004 | 09:04 AM
rlaifatt's Avatar
I've bent the backing plate of the pads before, but never seen anything that bad. Did the caliper itself fail in any way to cause this, or was it all just due to over use of the pads?
Old May 29, 2004 | 09:14 AM
cdelena's Avatar
[QUOTE]Originally posted by krazik
chris:
Old May 29, 2004 | 09:21 AM
bartekb93's Avatar
I've found myself in the same situation last year.
What started out as "a little more brake fade" at 1st, ended up becoming a nice paper weight for my desk. 2 brake pistons just about welded to the backing plate.
