For sale: Tein RA Coilover Suspension.I'm asking $1000 plus shipping. The suspension has about 10,000 miles on it with some minor little nics and scratches from everyday use. There are no leaks or squeaks. Near perfect condition. I've never tracked the car. I'll be selling the suspension with both sets of springs. The set on the shock is 10kg/mm^2, and the second set is 8kg/mm^2. I never swapped the springs, but you may want to use the 10's up front and the 8's in the rear. The additional set of springs cost me about $200. They will be included in the price.
The Type Flex lists for $1430 and the Type RA lists for $1840. This is info from www.tein.com. Type Flex is a slightly less aggressive street setup that can be used with the newer EDFC(remote compression/damper controller). RA is a track/street setup that also has a helper spring. RA is also lighter weight due to it's design.
