California - Southern California S2000 Owners Southern California S2000 Owners
Cusco 3-Piece subframe install guide.
Old Jul 28, 2004 | 11:24 PM
oatnet's Avatar
Default Cusco 3-Piece subframe install guide.
OK, got the kit on. I quickly realized the folly of jacking up all four corners, but just jacking up the front worked OK. The install was pretty easy, the bolts were all agreeable, fitment was good. More comments after the install below.
Since I couldn't find any directions in english, I had no way of knowing how to install this. Below is the list of steps I went through, only to document what I did. If you choose to use them as instructions, use them at your own discretion - I might have done it wrong.
Kit installs at 20lbs, and includes:
Left bar (8lbs)
Right bar (8lbs)
Cross Bar (4lbs)
2 bolts (.2lbs)
Useless directions (no pictures) in Japanese
Neato sticker
Wrapped
Unwrapped
Tools needed:
6mm Allen wrench (L shaped)
17mm socket
19mm socket
rachet
torque wrench
1) Lay out the two side bars with the left/right labels facing down; left is driver right is pssenger.
2) Lay out the cross bar between them with the hump pointing at the front of the car.
3) Using the 17mm socket and the 6mm Allen wrench, lightly bolt the cross bar, with the hex nuts facing up; it is easy to get the Allen wrench in there to tighten it right before you finish the front.
4) EBrake, 6th gear, and chock up the back wheels before jacking the front end WAY up. I used jackstands and had ramps lined up under the front tires just in case.
5) Using the 19mm socket, loosen the rear bolts (indicated by red circles above). Once loose, I was able to undo them by hand. They are fairly long, about 6", so it takes a while.
6) Pick up one bar at the back end, thread the bolt, and give it a few hand turns to anchor it but don't bolt it down yet. Be cautious, don't cross thread it! Pick up the other bar, do the same. Your install should look like this:
7) Using the 17mm socket, remove the front boltsas seen above. They are about 8" long, so they take an even longer while than the rear bolts. Once loosened, I was also able to remove these by hand.
8) Thread the front bolts through each side of the brace and loosely tighten them by hand.
9) Do your best to center the brace across all 4 bolts.
10) Tighten down the back bolts with the 19mm rachet until they are just snug, but do not apply torque. You will notice they rotate slightly as they snug up.
11) Tighten the front bolts until you have about an inch and a half of clearance as seen above.
12) Use the 6mm Allen wrench and 17mm rachet to tighten the bolts on the crossbar (not the ront bolts!). I don't know what the torque specs are on this, and I bolted them down pretty damn hard.
13) Tighten the front bolts down the rest of the way.
14) Torque the front and rear bolts to factory specs:
Front bolts: 59 N.m (6.0 kgf.m, 43 lbf.ft)
Rear Bolts: 103N.m (10.5 kgf.m, 76 lbf.ft)
Take a picture, you are done! Ae is what mine looked like.
Above is a shot of the front Bolt, in place. Notice where the gold Muz Whiteline Cross Brace ends (same spot as X-braces and how the subframe brace is bolted to the same piece. The Cusco brace actually bolts to the bottom of the strut, the bolt beneath the whiteline. Either way, if you scroll up to the back bolts with red circles, you see that this is the start of the rear suspension. The subframe ties the front and rear suspension together, as far as I can see.
So I took it for a ride, and I definitely feel a BIG difference. Oddly, I actually feel like the back end is taller, I had to tip my seat back. The ride is definitely stiffer. I feel like I can kick the back end out more easily than I would like, but it is also much more controlled. I can see how this would be a big improvement on the track, I need a few days to see how I feel about it on the street. I think I will end up liking it though...
-JD
Old Jul 29, 2004 | 07:50 AM
Reflexx's Avatar
So, you are feeling a significant difference even after you already had the X-brace?
Old Jul 29, 2004 | 07:55 AM
OverBooster's Avatar
thanks for the guide
Old Jul 29, 2004 | 08:04 AM
GPW02S2's Avatar
Great write-up. Im going to install mine today
Old Jul 29, 2004 | 08:47 AM
meth's Avatar
does this improve stability in front or in rear? or both?
Old Jul 29, 2004 | 08:54 AM
oatnet's Avatar
Yes, I am feeling a big difference, but I have having trouble defining exactly what it is. Definitely stiffer, maybe even too stiff - I need to get used to it and then take it through some twisties. On one of the other threads someone posted that they coudn't feel any difference - I just can't imagine why not.
The X brace was different - right away I could tell what it fixed - but that was a matter of control on cornering. I think this one is a matter of control of the back end.
The X brace and the subframe do very different things, as far as I can tell. The X brace locks the bottom of the front suspension to the chassis. The subframe locks the back suspension to the front suspension.
You are welcome! Putting one in?
Cool, LMK what you think about it when it is on.
-JD
Old Jul 29, 2004 | 08:57 AM
oatnet's Avatar
I would have to say the changes are in the rear.
-JD
Old Jul 29, 2004 | 09:02 AM
meth's Avatar
thanks great write-up, now it looks like i can attempt this on my own.
Old Jul 29, 2004 | 09:47 AM
krazyjon's Avatar
great post
im waiting to see your post ater you take your car through the twisties or on the track.
where did you get it and for how much
Old Jul 29, 2004 | 09:49 AM
ashmason's Avatar
We have gone different routes... I just got my Koni's, will fit them next week. Maybe we can hook up and swap rides for a few twisties in PV?
My old complaint about your setup is the color clash!
Looking good!
