Cant get my cel code
Old Aug 20, 2004 | 05:35 PM
tru's Avatar
tru
Default Cant get my cel code
my car is a 2002 and im jumping the bottom left with 4 fromt he left on the top row. my abs light blinks 1-5 but my cel doesnt blink? am i doing something wrong? sorry this is getting fustrating cause thing keep on happening and i only had this car for a few months
Old Aug 20, 2004 | 06:10 PM
Slows2k's Avatar
Check Modifry's site for a full write up on pulling flash codes.
http://www.baustnet.com/honda/misc/dtc.htm
Old Aug 20, 2004 | 06:25 PM
tru's Avatar
tru
i used his site as reference. did exacly what it said except my harness is located on the drivers side
Old Aug 20, 2004 | 06:44 PM
Slows2k's Avatar
I'd double check that you are getting the correct pins. Is the CEL on? If no DTC's are stored I don't believe it will flash.
Old Aug 20, 2004 | 07:57 PM
tru's Avatar
tru
yes my cel is on my abs is on also. i tried looking for the list of abs codes but i cant find it. i just ordered a helm manual, hopefully the list in in there. tahnks for your help
Old Aug 23, 2004 | 04:46 PM
tru's Avatar
tru
bump
Old Aug 24, 2004 | 04:36 PM
C6400hp's Avatar
DTC:11- Right front wheel sensor(open/short to body ground/short to power)
DTC:12- Right front wheel sensor(electrical noise/intermittent interruption)
DTC:13- Left front wheel sensor(same as 11)
DTC:14- Left front wheel sensor(same as 12)
DTC:15 -Right rear wheel sensor( Open/short to body ground /short to power)
DTC:16- Right rear wheel sensor(Electrical noise /intermittent interruption)
DTC:17- Left rear wheel sensor(open/short to body ground/short to power)
DTC:18- Left rear wheel sensor(electrical noise/intermittent interruption)
DTC:21- Right front pulser
DTC:22- Left front pulser
DTC:23- Right rear pulser
DTC:24- Left rear pulser
DTC:31- Solenoid
DTC:32- Solenoid
DTC:33- Solenoid
DTC:34- Solenoid
DTC:35- Solenoid
DTC:36- Solenoid
DTC:37- Solenoid
DTC:38- Solenoid
DTC:41- Right front wheel lock
DTC:42- Left front wheel lock
DTC:43- Right rear wheel lock
DTC:44- Left rear wheel lock
DTC:51- Motor lock
DTC:52- Motor stuck off
DTC:53- Motor stuck on
DTC:54- ABS fail safe relay
DTC:61- Low FSR + B voltage
DTC:62- High FSR + B voltage
DTC:71- Different diameter tire
DTC:81- CPU diagnosis , and ROM/ RAM diagnosis
Hope this is what you needed!
Old Aug 24, 2004 | 05:16 PM
tru's Avatar
tru
THANKS CANDYASS!!!
Old Aug 24, 2004 | 05:34 PM
C6400hp's Avatar
No problem.
Old Aug 24, 2004 | 05:52 PM
alexf20c's Avatar
Just go to AutoZone.
