Loss of power! Please help!
It's been 2 months since i brought my s2k, which has a problem ;
My car is 2001 S2000 , let me explain what i did to try solve the problem;
Mechanics from 3 different countries contacted,
-2 Diagnostics checks in different computers,no problems found
-New Iridium spark plugs,
-Injectors got cleaned,
-Valve adjustments,
-100 octanes 5 star unleaded used all the time,
-Reseting the ECU many times,
Non of these solved the problem.
Let me explain the problem now, i dont know if its electrical of mechanic ,
my car , not all the time, sometimes loose power and it gets hard to drive, hard to accelerate, no performance at all, feels like your driving an old cabrio, than its back to normal again. When it does this the response to the gas pedal dies, the torque, the bhp, everything goes down, the car does this for a while, than its back to normal again, the superb s2000. I'm thinking of selling it bcoz of this problem, cant drive it like this, but i love the car and dont wanna sell it, so people please please help me to solve this! what might this be? ??? Note: the problem decreased a little bit when i started to use high quality unleaded petrol. Please help me
-Valve adjustments,
is it in vtec or everywhere in the rev-range......some simple things not to overlook are to make sure it has 3 bars on the temp gauge (though you should know that by now) or try doing the "MAP whack" with the map sensor, if you dont know how do a search on "MAP whack" and youll find it. It may not cure the problem but it is a very simple and easy thing to do.
If you are using high octane fuel and still seeing the problem, I'd say try the MAP whack (see the FAQ for the "very technical procedure").
Oops... I just went back and read that he had already done 100octane and still saw the problem.
I've got to learn to read better. In that case, I'd say that he should definitely try the MAP whack.
Heat bog can do that to some degree.
Do you have a CAI? If so, the filter can become saturated with water and cause problems short of hydrolock.
FWIW, I just had a problem with an electrical short that disabled the CO2 sensors. With them not working the air fuel ratio went whacky and VETC was no longer a kick in the pants.
My guess is the MAP sensor. My '01 used to do the same thing. I'd have to take a plastic-handled screwdriver and hit it with the plastic end, fairly gently... but with more force than a "tap."
I had a similar thing happen and the "map whack" appeared to clear it, but that was only because the ECU was being reset each time. Turned out to be the vacuum control valve (its name was something like that anyway). The fault was only intermitent, but replacing that removed the problem totally.
I just assumed after all that other stuff he tried/went through this wouldnt be a possibility lol...
