Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
snow tires for the winter car
Old Nov 3, 2004 | 12:15 PM
comets's Avatar
Default snow tires for the winter car
Toyo G02?
Perilli Wintercraver?
Kumho KW 17 or 19?
Price range is around the same, but which one should I get?
Old Nov 3, 2004 | 02:02 PM
xviper's Avatar
Are you picking these because of price? Blizzaks tend to be the most widely used but if you must pick from only those you posted, I suggest you go check them all out. Look for good deep grooves that will get you through the snow. Look for lots of ice siping (those little wavey lines in the rubber) to get you through the ice. Also, push on the rubber in the tread itself. Get the one that is the softest. This will get your through the cold. The softer the rubber, the better is it in the cold but the more it will wear in the warm.
Old Nov 3, 2004 | 02:13 PM
Jasonoff's Avatar
Banned
The KW19's are good...
Old Nov 3, 2004 | 02:21 PM
s2ksimon's Avatar
I'd google search a review on them and see any comparison charts as well
maybe tirerack ?
Old Nov 3, 2004 | 02:23 PM
comets's Avatar
http://www.toyotanation.com/forum/t54344.html
^^^ the above link is where I am looking to buy the tires from...
from your information, visually the Toyo and KW19 seems to be nice....
$100 difference between the two, I might go for the KW19's...
Old Nov 3, 2004 | 02:24 PM
comets's Avatar
Funny thing Simon,
I was doing some research last week and the Kumho's were given bad review! It was dissqualified because it failed to provide traction on slippery surface. I forgot where I read it, but that site also gave Artic Alpines a bad review as well....
~ arthur
Old Nov 3, 2004 | 02:27 PM
s2ksimon's Avatar
reviewS then
Old Nov 3, 2004 | 03:18 PM
hapa's Avatar
Michelin just came out with the Artic Ice. They are the new tire that is taking over from the Alpin, but I'm not sure you may need a Pilot Alpin 2 that is the high performance sport winter tire.
They are probably out of your price range though!
Old Nov 3, 2004 | 03:55 PM
Strife350z's Avatar
I just bought the kw19s for our s2k... awesome looking tread, and I've heard very very good things about them
On my Z, I run Toyo Observe g02+, awesome tire... it's hard to trigger traction control with these things unless you're driving at speeds you shouldn't be
Old Nov 3, 2004 | 04:11 PM
Jasonoff's Avatar
Banned
I had KW15's on the RSX way back. They seeemd to do just fine.
The KW11's had a softer sidewall and a much lower speed rating.
