Loose stick shift?
Old Feb 3, 2005 | 11:29 AM
Amer's Avatar
Default Loose stick shift?
Anyone else have a loose feeling stick shift? Mine is fairly loose unlike other S who don't have alot of play when its in neutral, mine is loose. When I shift from 1st to 2nd or any other gear the shift feels too flimsy. I have a comptech flywheel, ACT clutch with OEM disk. Anyone got some advice? Think Honda will warranty this? Thanks inadvance.
Old Feb 3, 2005 | 01:12 PM
Stale_Hotdog's Avatar
I had the same problem when I brought my car in for clutch warranty work. It had nothing to do with the clutch. A small nylon bushing in the shifting mechanism had worn out and cracked in half. It was replaced under warranty.
Old Feb 3, 2005 | 01:45 PM
Amer's Avatar
was your stick shift really loose? like you could jiggle it 1-2 inches loose? I'm gonna have to make an appt. to get it checked.
Old Feb 3, 2005 | 04:26 PM
Yes it became extremely loose when I went to pick up the car. I told the service advisor and he kept it for another day. After it was fixed he showed me the broken bushing and apologized for the inconvience.
P.S I replied to your pm as well
Old Feb 3, 2005 | 04:29 PM
revhi's Avatar
Interesting, my g/f's S has a loose shifter to. You can push it to the right in neutral and it wont center itself again.
Old Feb 3, 2005 | 05:47 PM
http://www.hondaautomotiveparts.com/...3S2A01_B34.gif
the part labeled #8 is the most likely culprit of your problem.
Old Feb 3, 2005 | 09:00 PM
Amer's Avatar
thanks Stale Hotdog
Old Feb 4, 2005 | 11:48 AM
Squeezer's Avatar
i had the same problem and yes part #8 fixed it
Old Feb 4, 2005 | 04:24 PM
Amer's Avatar
Anybody fix this problem themselves without going to the dealer? just wondering.
Old Feb 5, 2005 | 05:07 AM
Squeezer's Avatar
well of course you have to go to the parts dept at the dealer and order part #8. after that you take off the shift knob. there is a lock nut under it you turn one way and turn the knob the other way and the knob comes off. then take off the center console. on the 00-03 you just tug on it real hard and the clips unhook and it comes out (dunno about on 04's tho). then at the base of the shifter is 3 10MM bolts under a rubber boot, undo them and the shifter comes right out. put the part #8 on the bottom (it snaps on) then put some grease all over the bottom of the stick and part #8, and then pu tit back on. it has a grey thing that pivots, and it only goes in one way so you can't put the stick on backwards. and then put back on the 3 10mm bolts, slde back down the boot, put the console back on, and then put the shift knob back on.
