Modified Saner Swaybar for Sale
Old Feb 9, 2005 | 02:26 PM
Gloffer's Avatar
Default Modified Saner Swaybar for Sale
For all you auto-xers/track drivers waiting for a sway bar from Saner, I have a used modified one for sale. I used the bar in its stock configuration for about a year for both auto-cross and ~3000 miles of street driving. I got a good deal on a Comptech swaybar so I decided to try the Comptech.
I got the Saner modified at a local machine shop. The modification provides more end-link clearance and an extra adjustment hole. The fourth hole will make the bar stiffer, as required for grippier auto-cross surfaces like concrete. It has new McMaster-Carr end links and the end-links from Saner. It is the latest version of the Saner swaybar and comes with polyurethane bushings. The older Saner swaybars have neoprene rubber bushings. It's not cheap, but even at $450 it's still ~$200 less than a Comptech and ~$100 less than a Gendron.
Pictures and details are here. The stock bar has been sold, but the modified bar is still available.
https://www.s2ki.com/forums/index.php?showtopic=266829
If you want, I can even do the grease zirc modification to the Saner mounts before I send the bar to the purchaser. No additional charge.
https://www.s2ki.com/forums/index.ph...c=265670&st=25
Old Feb 11, 2005 | 11:23 AM
Gloffer's Avatar
Modified sway bar is sold!
Thanks
Monch
Apr 25, 2012 11:48 AM
jeallen
Oct 17, 2009 11:42 PM
designfreak
Oct 28, 2005 02:53 PM
spa-zz
Oct 8, 2005 07:20 AM
TJ Stooker
Jul 3, 2003 04:32 PM
