Australia & New Zealand S2000 Owners Members from the land downunder.
Install, Rear Speakers
Old Jun 27, 2005 | 10:47 PM
cjw07's Avatar
Default Install, Rear Speakers
This is a pretty basic install, fairly quick and easy. I didn't want to spend a heap but just wanted better sound.
I used http://keedyweb.net/honda-s2000/tech/Rear-...r-speakers.html as a reference. Thanks Mr Keedy.
Firstly, remove rear panels.
Check to make sure the speaker magnet will fit in between the metal behind the panels.
Mark out where it is to go, remember, measure twice, cut once.
Use a Dremel tool or similar to cut out the hole, clean up with the metal brush attachment.
I am using 4" speakers I had lying around, but apparently 5" also fit without much of a problem.
Mount the speaker.
Repeat on the other side. run the cable from the passenger side under the secret compartment to the drivers sideand tuck under te carpet toword the floor. Put the rear panels back on.
Run both cables tucked up under carpet of the centre console, held in place by the push studs.
Using Lucids guide- http://lucidauto.com/Merchant2/merchant.mv...ode=radioremove
Remove the head unit.
Below is the back of the HU, Note the loom is missing 4+ points, these are the rear speaker points, use the above Keedyweb link to decifer which points are which. I am curruntly trying to get my hands on the right sized pins to fit into the loom ( Sorry Matt, they were too big, Next size down, thanks for your help) so i have only temp installed these in place.
Put the HU back in and test. Just like a bought one.
Thanks to Dbzerk for your help, as well as Mr Keedy and Lucid.
Chris.
Old Jun 27, 2005 | 11:32 PM
fisting dwarves's Avatar
Good stuff. Wait until you get it up and running; you'll certainly notice the difference.
Old Jun 27, 2005 | 11:47 PM
dbzerk's Avatar
Great write up Chris!! very nice install!!
Old Jun 28, 2005 | 12:32 AM
blk2000's Avatar
Nice work!!!! Is it hooked up yet? Whats the sound difference like? Is it worth the hassle?
Old Jun 28, 2005 | 01:33 AM
Vuey's Avatar
cjw07
mate looks like you did a really good job !
mate , where did you get the mobile phone holder ? ive been looking for something like that !
I would never dare attempt to do this install on my own ! as i would get freaked out if i stuff something up !
Sydney Crew
Anyone out there know of a someone who could do a similar install ?
As i would like to get this done for my car , as i can hardly hear anything with the roof down . I am assumming you can hook up extra speakers onto a stock head unit ?
Old Jun 28, 2005 | 02:16 AM
AusS2000's Avatar
Originally Posted by Vueyjr,Jun 28 2005, 07:33 PM
Sydney Crew
That ain't gunna cut it. The stock headunit puts out something like 12w and the front speakers in an '00 are made from recycled egg cartons.
I recommedn replacing the front speakers and installing a small amp as the starting point.
Old Jun 28, 2005 | 05:31 AM
dbzerk's Avatar
I have a good set of splits, one sub and a decent amp..
With the top down the car next to me can hear what im playing.. (if i want them to )
Rear speakers are good but personally you can get away without them..
https://www.s2ki.com/forums/index.php?showtopic=289014
Old Jun 28, 2005 | 05:48 AM
Vuey's Avatar
AusS2000
Thanks mate , ive replaced the front speakers with a set of 3 way pioneers . improved sound quality , but nothing great .
Yeah , i was shocked too when i saw the stock speakers ... felt totally rorted !
gotta pump that trance !
Old Jun 28, 2005 | 02:32 PM
cjw07's Avatar
Hey blk2000, yeah, its all hooked up, gave it a quick spin around the block top down, but as the weather in brissy has been RS the last couple of days i havent been able to get it out on the highway top down.
I don't need a doof doof setup, i just wanted to hear the sound top down, and sofar it has been well worth the hassel, i think the speakers are worth $50 odd and that was the only cost. took about 2 hours to install, but if i did it again it would take half that time.
Next job will be to change out the door speakers. OK Aus.
All in all, well worth it and a very easy install. I recomend.
Thanks for your coments guys.
Chris.
Old Jun 28, 2005 | 02:49 PM
cjw07's Avatar
Originally Posted by Vueyjr,Jun 28 2005, 01:33 AM
cjw07
Sydney Crew
Hey Vuey, the phone holder is the standard phone holder for the Sony Ericsson T630, i also have the holder for my SE P910 that clips onto the same bracket depending on which phone i am using.
Mate you could do this, it aint a hard one.
See ya.
Chris.
