That annoying key in the ignition beep...
Old Jul 9, 2005 | 12:16 PM
spyhunter's Avatar
Default That annoying key in the ignition beep...
I was under my dash last night checking out my wiring when I took a good guess as to which electronic box was the one with that annoying beep and it is the only one with 2 wires going into it, directly below the steering wheel. Popped the connector and whala! No more beep!
I was relieved that it was this simple. I guess the beeping may be handy for some people, but I have always disabled it in the Preludes that I used to own, and in those it was a bit trickier, because it involved opening up a bigger electronical box near the radio and breaking the beeper speaker off of the printed circuit board. Which was a much more permanent way of circumventing it, but I never missed it!
Just thought you all would like to know, if you didn't already!
SH
Old Jul 9, 2005 | 03:14 PM
darkknight1999's Avatar
Or you can just put a plastic screw in the door pop switch save you hunting around under the dash again
Old Jul 9, 2005 | 07:19 PM
jlucas's Avatar
Or use the same screw but just unplug the door switch before you put it back in.
Old Jul 11, 2005 | 06:44 AM
jdoe11's Avatar
How do you put a plastic screw in the door sensor? Do you have a pic?
RobinA3
May 1, 2019 10:39 PM
hirev
Aug 18, 2013 04:30 AM
bruce0293
May 24, 2013 10:10 AM
JakeAP1
Jul 8, 2010 11:53 PM
mcc601
Jan 6, 2002 05:10 AM
